Re: 2004.5 Cummins high EGT readings
[Re: camastomcat]
#1631979
06/11/14 10:38 AM
06/11/14 10:38 AM
Guitar Jones
Yeah 1500 degrees is something to worry about especially if it's doing this without a load or being worked hard. I would revert it back to the stock tune and see what happens.
Do you have a real pyrometer in the truck?
[Re: camastomcat]
#1631981
06/11/14 11:41 AM
06/11/14 11:41 AM
Guitar Jones
Possible it's an injector or the Edge unit or sender. If you can get a pyro gauge on it and confirm that would be best. Does it idle rough or anything when this happens?
