Headliner Install Question #1630588
06/08/14 06:27 PM
06/08/14 06:27 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
So, I've been collecting parts for years. Now is the time to do the headliner. I have it laid out, but it seems really big. The listing pockets and material extend well beyond the length of the bows. Talking a good 6+ inches per side when the bow is laying in the center.
Are these things "universal fit" where they can be and I just need to trim *a lot* of material off?
Bows are original, and in the correct order.
For my 68 Dart...
383, Hemi 4-Speed, AlterKtion, D60
Re: Headliner Install Question [Re: Crazy68Dart] #1630589
06/08/14 06:37 PM
06/08/14 06:37 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
For my 68 Dart...
it's been awhile since i've done one but keep in mind when you hit it with the hair dryer there will be shrinking and tightening. 6 inches per side seems excessive but i honestly don't remember how much 'slop' there is. if i remember right i didn't start out with having the sides with even amount of slop. i think i had most of the excess on one side and worked front to back, then tacked down on one side and worked it over to the other. i used those jumbo steel trap type paperclips to hold it until i was ready for the tack glue.
Re: Headliner Install Question [Re: Crazy68Dart] #1630590
06/08/14 06:39 PM
06/08/14 06:39 PM
Yes they have extra as they are trim to fit. 6"+ overhang per side does seem like alot of extra material tho & maybe that # fits several apps. I'd check the # & continue on. I've only did one (65 dart) & my advice is to be patient & dont be afraid to walk away when a slight snag develops (pun intended & yes it will) & come back the next day especially if it is your first one and you'll likely need to walk away several times. The concept looks simple but they ain't easy. I've developed alot of of patience thru the years for things mechanical & rarely get rattled in the shop/garage but that headliner tested me
Re: Headliner Install Question [Re: RapidRobert] #1630591
06/08/14 07:00 PM
06/08/14 07:00 PM
Canton, Ohio
Canton, Ohio
Pic 1
Re: Headliner Install Question [Re: Crazy68Dart] #1630592
06/08/14 07:00 PM
06/08/14 07:00 PM
Canton, Ohio
Canton, Ohio
Pic 2
Re: Headliner Install Question [Re: Crazy68Dart] #1630593
06/08/14 07:02 PM
06/08/14 07:02 PM
Canton, Ohio
Canton, Ohio
I'll look for a part number... but I've likely had this thing for a decade as I have collected the restoration stuff over the years.
That is the front-most bow (towards the windshield).
Re: Headliner Install Question [Re: Crazy68Dart] #1630594
06/08/14 07:03 PM
06/08/14 07:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that looks about right.
Re: Headliner Install Question [Re: mikemee1331] #1630595
06/08/14 07:11 PM
06/08/14 07:11 PM
Canton, Ohio
Canton, Ohio
Only markings on it are a faint CGPC "watermark" logo.
Okay... if this looks about right... wish me luck.
Re: Headliner Install Question [Re: Crazy68Dart] #1630596
06/08/14 07:22 PM
06/08/14 07:22 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
ahh, you'll be fine! they're not hard just frustrating as Rapid said. take your time, no cutting until you're 100% and that spray can tack glue can be messy so be careful. it doesn't set up right away so don't panic. when you're done and you tighten it up with the dryer you'll be amazed at how great it looks! my first one (69 RR) took me about 6 hours. the second, (72 charger) about 3.
Re: Headliner Install Question [Re: mikemee1331] #1630597
06/08/14 11:51 PM
06/08/14 11:51 PM
Canton, Ohio
Canton, Ohio
I also didn't mention the car has a cage... got as far as I wanted to tonight. So far so good.
Re: Headliner Install Question [Re: Crazy68Dart] #1630598
06/08/14 11:51 PM
06/08/14 11:51 PM
Canton, Ohio
Canton, Ohio
47
Re: Headliner Install Question [Re: Crazy68Dart] #1630599
06/08/14 11:52 PM
06/08/14 11:52 PM
Canton, Ohio
Canton, Ohio
-12
Re: Headliner Install Question [Re: Crazy68Dart] #1630600
06/08/14 11:53 PM
06/08/14 11:53 PM
Canton, Ohio
Canton, Ohio
Re: Headliner Install Question [Re: Crazy68Dart] #1630601
06/08/14 11:54 PM
06/08/14 11:54 PM
Canton, Ohio
Canton, Ohio
Re: Headliner Install Question [Re: Crazy68Dart] #1630602
06/08/14 11:55 PM
06/08/14 11:55 PM
Canton, Ohio
Canton, Ohio
Re: Headliner Install Question [Re: Crazy68Dart] #1630603
06/08/14 11:55 PM
06/08/14 11:55 PM
Canton, Ohio
Canton, Ohio
Re: Headliner Install Question [Re: Crazy68Dart] #1630604
06/08/14 11:56 PM
06/08/14 11:56 PM
Canton, Ohio
Canton, Ohio
New steering wheel... I think it compliments the GT badge on the door panel nicely.
Re: Headliner Install Question [Re: Crazy68Dart] #1630605
06/09/14 11:02 AM
06/09/14 11:02 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
I just finished my 2nd install. The first was a nightmare. It was the middle of a very cold winter and the headliner had been in a box for 3 years. Getting all the folds out was a major pain. My second was just finished yesterday. It went much easier. Use a spray mister with water and a hair dryer to get out the wrinkles. Start from the middle out and work front to back. Good luck.
Re: Headliner Install Question [Re: fastmark] #1630606
06/09/14 02:37 PM
06/09/14 02:37 PM
Canton, Ohio
Canton, Ohio
Thanks for the tip. So lightly mist the headliner with water and then use the hair dryer? Sort of a pseudo steam press?
Mine has been in the box for 10 years... I should be in good shape...
Re: Headliner Install Question [Re: Crazy68Dart] #1630607
06/10/14 11:46 PM
06/10/14 11:46 PM
Canton, Ohio
Canton, Ohio
This is going (slightly) better than expected. I am at the point of stretching, clamping, etc.
For the sail panels, does the liner get glued to the inner panel board? Maybe not...
For the sail panels, is it better to glue the side by the quarter windows and then pull into the teeth or the opposite?
