sneeze valves for MP Crossram.. Anyone ? #1630402
06/08/14 11:08 AM
06/08/14 11:08 AM
USA
SSAAHemiFan Offline OP
USA
I want to add 2 wilson nitrous pop off plates to my Hemi crossram and was wondering if anyone had any pics of there setup ?
I want to use 2, either in the top plates or over each freeze plug hole at the ends (I think the ends would look better)
A friend just had his Indy bathtub pop at startup - He only had 1 blow off plate and it still caused some damage, but not as severe as another buddy who had one blow with no relief valve
Still not alot of surface area conpared to 8 throttle blades so I wonder if the 2 wilsons would be enough or a waste of money ?
They use a 1.25 hole each. This is a street car so I need a relief that is re-settable.
Re: sneeze valves for MP Crossram.. Anyone ? [Re: SSAAHemiFan] #1630403
06/08/14 11:48 AM
06/08/14 11:48 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
These are not Wilson's , but this is what I am using.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: sneeze valves for MP Crossram.. Anyone ? [Re: Hemi Allstate] #1630404
06/08/14 05:26 PM
06/08/14 05:26 PM
USA
USA
Mark - Are you using 2 in your manifold ?
It looks good mounted in the end.
Any chance you remember the manufacturer?
Thank You for the picture
Re: sneeze valves for MP Crossram.. Anyone ? [Re: SSAAHemiFan] #1630405
06/08/14 06:03 PM
06/08/14 06:03 PM
Mt. Eden Ky.
Mt. Eden Ky.
Yes I am using two. They are Nitrous Proflow.
Here is a link : http://www.nitrousproflow.com/products/burst-panels/manifold-pressure-relief-valve.html
Mark
1996 Ram 1500 Sport
1968 road runner
Re: sneeze valves for MP Crossram.. Anyone ? [Re: Hemi Allstate] #1630406
06/08/14 06:06 PM
06/08/14 06:06 PM
USA
USA
Thanks for all the info Mark.. Appreciate it
Re: sneeze valves for MP Crossram.. Anyone ? [Re: SSAAHemiFan] #1630407
06/08/14 06:06 PM
06/08/14 06:06 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I bought this for my STR-14 intake but have yet to use either one
Re: sneeze valves for MP Crossram.. Anyone ? [Re: brads70] #1630408
06/08/14 06:28 PM
06/08/14 06:28 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
How tall is that item, trying to figure the amount of clearance needed, it looks nice.
Re: sneeze valves for MP Crossram.. Anyone ? [Re: jcc] #1630409
06/08/14 06:31 PM
06/08/14 06:31 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
You could just run aluminum carb studs and watch the carbs launch off it.
Just kidding....
Re: sneeze valves for MP Crossram.. Anyone ? [Re: jcc] #1630410
06/08/14 09:10 PM
06/08/14 09:10 PM
Mt. Eden Ky.
Mt. Eden Ky.
If you still need the dimensions tomorrow, I can measure it for you.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: sneeze valves for MP Crossram.. Anyone ? [Re: Hemi Allstate] #1630411
06/08/14 10:59 PM
06/08/14 10:59 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Thanks, it would help me pick a location for mounting, as in my case it will be tight.
Also, would anybody be concerned about dumping raw fuel if it was on bottom of a manifold? seems like the sneeze would consume all the fuel anyway.
Re: sneeze valves for MP Crossram.. Anyone ? [Re: jcc] #1630412
06/09/14 01:06 AM
06/09/14 01:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I popped my Indy manifold last year. I did add a nitrous relief valve. However after learning how to start the engine I've never had an issue again. I used to crank it with no igntion and then click it on while cranking. Bad idea, fills the manifold with fuel and BAM! Pump off during start-up (safety precaution). Cold start, 2-3 pumps, let set 30 seconds, then 1 pump, crank with throttle 1/3 open. Very cold, choke carbs with covers or hand. Warm, 1/3 throttle and crank.
If for some reason it doesn't start, wait for a few minutes with the throttles open , then repeat steps. Your intake will thank you.
Doug
Re: sneeze valves for MP Crossram.. Anyone ? [Re: jcc] #1630413
06/09/14 12:33 PM
06/09/14 12:33 PM
Mt. Eden Ky.
Mt. Eden Ky.
I measured 1.150" from mount surface to top of nyloc nuts. The nuts could be tightened a small amount.
It was also suggested here by Monte that plastic/nylon fasteners used to mount the lid allow for a large backfire. But you would have to be prepared to replace them on the street.
Hope this helps.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: sneeze valves for MP Crossram.. Anyone ? [Re: Hemi Allstate] #1630414
06/09/14 01:55 PM
06/09/14 01:55 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Thank you Mark.
Re: sneeze valves for MP Crossram.. Anyone ? [Re: Hemi Allstate] #1630415
06/09/14 02:06 PM
06/09/14 02:06 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
If you have room, would this do the same thing? A bit pricey, but another option...
http://inductionsolutions.com/shop/burst-platespop-offs/pressure-relief-plate/
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: sneeze valves for MP Crossram.. Anyone ? [Re: OUTLAWD] #1630416
06/09/14 04:10 PM
06/09/14 04:10 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I like the concept and simplicity a lot, and in my situation it would be of no concern, but I wonder do the 4 side ports cause any disruption of the air flow in critical applications?
Re: sneeze valves for MP Crossram.. Anyone ? [Re: jcc] #1630417
06/09/14 04:50 PM
06/09/14 04:50 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Because of the area of the holes, even with two pop off valves, chances are really good that you will bend the throttle blades when it sneezes. That is why I like the plastic bolts. It simply lifts the top with NO damage to any parts. Take the broken plastic bolts out, reglue the top, new bolts and you are ready to go.
Couple weeks ago I had a Top Sportsman customer develop an ignition box issue and knocked the top off the sheetmetal intake twice in qualifying. Usually a backfire wrecks a sheetmetal intake. His was not hurt, found the box problem and ultimately won the race that weekend.
Plastic bolts for the win.........LOL!!!
Monte
