Adding refrigerant to an '74 RV2, Which port ? #1630009
06/07/14 11:30 AM
06/07/14 11:30 AM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
The last time I had to add some refrigerant to my RV2 AC system was about 8 years ago and I've forgotten which low pressure port to use! It's a '74 B body with the original AC setup.
As R-12 is not available/affordable I'm using Hotshot 414B for refrigerant. This seems to work well.
Re: Adding refrigerant to an '74 RV2, Which port ? [Re: 74RALLYE] #1630010
06/07/14 11:56 AM
06/07/14 11:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Large line low pressure = charge side.The fittings typically cant be used backwards.Suction might also be marked on the line near compressor.Rocky
Chrysler Firepower
Re: Adding refrigerant to an '74 RV2, Which port ? [Re: therocks] #1630011
06/08/14 09:50 AM
06/08/14 09:50 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Here's the rule I always use: "high pressure side of the compressor goes to the condenser" Don't charge that side.
Re: Adding refrigerant to an '74 RV2, Which port ? [Re: TooMany62s] #1630012
06/08/14 11:22 AM
06/08/14 11:22 AM
I always remember that C comes before E in the alphabet so the condensor is in front of the radiator and the evaporator is under the dash (rearward) and it would make sense that that the high side (high psi) would be hot (compressed from the compressor) and would be going forward to the condenser to be cooled just like the radiator cools the coolant so you would not want to open up the high side to add anything more to it cuz you are wanting to draw the freon into the system. There's only 2 ports I just dont have a mental pcture of which one is whaere at the moment but likely it'd be easy to tell when you open the hood
Re: Adding refrigerant to an '74 RV2, Which port ? [Re: RapidRobert] #1630013
06/08/14 01:46 PM
06/08/14 01:46 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
That and most later cars have different size ports.they made them fool proof.You cant fit the charge on a high side fitting as they are larger.Rocky
Chrysler Firepower
Re: Adding refrigerant to an '74 RV2, Which port ? [Re: therocks] #1630014
06/08/14 04:04 PM
06/08/14 04:04 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Always charge on the low side ( blue hose) The way I remember it is Red hose = high pressure side = high pressure means heat = front of the car
Blue hose = low side = cold side = rear of the car
anyway,,, I can't say for sure about 1974 ,,,but for 1969 both of the connector fitings are the same size.
Re: Adding refrigerant to an '74 RV2, Which port ? [Re: 74RALLYE] #1630015
06/09/14 11:15 AM
06/09/14 11:15 AM
Creedmoor, NC, USA
74Charger Offline
74Charger  Offline
Creedmoor, NC, USA
Use the 1/4" male flare port that is on the large or suction side hose, not the port that is on the compressor head.
The port on the small hose is the discharge or high-side pressure fitting.
the fitting on the head is used in conjunction with the low-side or suction side fitting to evaluate performance of the POA valve internal to the RV2 compressor.
