Re: Adding refrigerant to an '74 RV2, Which port ?
[Re: 74RALLYE]
#1630010
06/07/14 11:56 AM
06/07/14 11:56 AM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Large line low pressure = charge side.The fittings typically cant be used backwards.Suction might also be marked on the line near compressor.Rocky
Chrysler Firepower
[Re: TooMany62s]
#1630012
06/08/14 11:22 AM
06/08/14 11:22 AM
RapidRobert
I always remember that C comes before E in the alphabet so the condensor is in front of the radiator and the evaporator is under the dash (rearward) and it would make sense that that the high side (high psi) would be hot (compressed from the compressor) and would be going forward to the condenser to be cooled just like the radiator cools the coolant so you would not want to open up the high side to add anything more to it cuz you are wanting to draw the freon into the system. There's only 2 ports I just dont have a mental pcture of which one is whaere at the moment but likely it'd be easy to tell when you open the hood
[Re: RapidRobert]
#1630013
06/08/14 01:46 PM
06/08/14 01:46 PM
therocks
Niles , Ohio
That and most later cars have different size ports.they made them fool proof.You cant fit the charge on a high side fitting as they are larger.Rocky
Chrysler Firepower
[Re: 74RALLYE]
#1630015
06/09/14 11:15 AM
06/09/14 11:15 AM
Posts: 174 Creedmoor, NC, USA
74Charger
Creedmoor, NC, USA
Use the 1/4" male flare port that is on the large or suction side hose, not the port that is on the compressor head. The port on the small hose is the discharge or high-side pressure fitting. the fitting on the head is used in conjunction with the low-side or suction side fitting to evaluate performance of the POA valve internal to the RV2 compressor.
