Which starter/flexplate do you use with 16-1 comp? #1629927
06/07/14 10:58 AM
06/07/14 10:58 AM
Salt Lake City
camastomcat Offline OP
Salt Lake City
I'm getting tired of struggling with starters and stripping flexplates. My 572 B1 has 16-1 compression, starters aren't lasting. I use the JW Ultrabell, and the JW flexplate. Just curious what the racers use that race weekend after weekend and are successful with.
Re: Which starter/flexplate do you use with 16-1 comp? [Re: camastomcat] #1629928
06/07/14 12:02 PM
06/07/14 12:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your cranking cyl pressure
Re: Which starter/flexplate do you use with 16-1 comp? [Re: camastomcat] #1629929
06/07/14 12:04 PM
06/07/14 12:04 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
I'm assuming you have a start retard and don't turn the ignition on until the starter gets the engine turning?
Re: Which starter/flexplate do you use with 16-1 comp? [Re: GTS340] #1629930
06/07/14 01:05 PM
06/07/14 01:05 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
You need a Meziere flex plate & while the Meziere starter is the again the best I prefer the Power Master Ultra Torque starter because with a 16 volt battery it will turn your engine faster.
I use a Meziere flex plate Power Master Ultra Torque starter with a Rock 16 volt battery with my dist. locked out @ 35 degrees and don't have to worry about anything else.My engine never ever kicks back,kick back is what gets your stater & flywheel.
By using the Ultra Torque starter & Rock 16 volt battery that turns the engine much faster it may be like putting a band aid on the problem if someone want's to call it that but if it works I call it Fixed.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Which starter/flexplate do you use with 16-1 comp? [Re: MRMOPAR622] #1629931
06/07/14 02:17 PM
06/07/14 02:17 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
too bad a cummins starter couldntr be used
Re: Which starter/flexplate do you use with 16-1 comp? [Re: MRMOPAR622] #1629932
06/07/14 03:11 PM
06/07/14 03:11 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Re: Which starter/flexplate do you use with 16-1 comp? [Re: boatracer572] #1629933
06/07/14 09:10 PM
06/07/14 09:10 PM
Arizona
Chris'sBarracuda Offline
Arizona
Tom..
I've used these for as long as I can remember..
http://www.reactorproducts.com/
Replaceable ring gear too..
But I've never needed to replace one..
I use the power master starter..
Chris..
Re: Which starter/flexplate do you use with 16-1 comp? [Re: Chris'sBarracuda] #1629934
06/07/14 11:55 PM
06/07/14 11:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO Reactor is the best I have ever used. Have not tried Meziere but I have also never had an issue with the JW and mopar mini. Well other than dropping one off my toolbox and breaking it. Also have not had issues with the Powermaster mini either.
FWIW I always getting the engine spinning before hitting the ignition switch. Also I do not use any starter retard either.
Re: Which starter/flexplate do you use with 16-1 comp? [Re: Al_Alguire] #1629935
06/08/14 01:34 AM
06/08/14 01:34 AM
Salt Lake City
Salt Lake City
How does the reactor flexplate work with the Ultrabell? Do you still need the spacer?
Re: Which starter/flexplate do you use with 16-1 comp? [Re: camastomcat] #1629936
06/08/14 06:08 AM
06/08/14 06:08 AM
Arizona
Arizona
Call there and talk to Olan.. Tell him your set up and he will fix you up.
I use a TCI adapter with the Reactor. Also use the TCI crank hub on the flexplate for converter spacing and centering.
Works well for me.
Chris..
Re: Which starter/flexplate do you use with 16-1 comp? [Re: Chris'sBarracuda] #1629937
06/08/14 11:28 AM
06/08/14 11:28 AM
Salt Lake City
Salt Lake City
Works well for me.
Chris..
Thanks guys, I'll check that out.
Re: Which starter/flexplate do you use with 16-1 comp? [Re: camastomcat] #1629938
06/09/14 10:56 PM
06/09/14 10:56 PM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
I also use the Power Master starter without any issues.
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
