New Best #1629850
06/07/14 03:54 AM
06/07/14 03:54 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
Made some changes yesterday on the 68`.
Removed the .920 t-bars and installed .880 t-bars.
Swapped 90/10 shocks replacing OEM style.
Removed sway-bar.
And.......changed the blower drive ratio.
Went from 2.23 ratio to 2.72 ratio.
Made 3-lbs boost @ 2.23 ratio
Now makes 6-lbs. with 2.72 ratio.
Took it for a drive WOW! what a difference...
So went to Quaker again tonight expecting to see improved hook and more power,did`nt exactly work out that way.
#1 1.71-60ft. spun bad lifted at 1,000 hoping to stay above 11.50.
#2 1.69-60ft. spun [Email]11.50@116.23mph.[/Email]
#3 Backed timing down to 28* and did harder burnout right up to the starting-line.
1.56-60ft. PULLED left wheel off the GROUND!! WOW ran [Email]11.35@115mph!!![/Email] New Best
Now the bad,,,, trans. has waved the white flag.
Slips into 3rd. Its a stock rebuild with my manual-valebody thrown in it.
What I learned this trip:
When it can get on top of the tires and spin on the street its a beast,feels ALOT more powerfull at 6-lbs boost than 3-lbs.Even at 30 MPH in 2nd gear it will come around under throttle.
More boost didn`t make any faster only harder to hook up. 3lbs versus 6lbs no real gain
More RPM on the shifts improves MPH,,slows E.T.
More timing is quicker,but harder to hook.
So I`m thinking for max performance: more gear,more converter,more traction........
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: New Best [Re: 6bblFLASH] #1629851
06/07/14 04:12 AM
06/07/14 04:12 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Nice Dennis! nice RR.. mine's a lot slower LOL
Re: New Best [Re: ademon] #1629852
06/07/14 05:24 AM
06/07/14 05:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice going. Congrats. Ron
Re: New Best [Re: 6bblFLASH] #1629853
06/07/14 10:36 AM
06/07/14 10:36 AM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
"So I`m thinking for max performance: more gear,more converter,more traction........"
uh oh
Mission Creep
Congratulations!
So me knowing almost nothing about boost: is it true that if you raised the boost to 14.7 psi then you would effectively doubled the displacement of the engine?
Then why didn't the mph pick up when you went from 3 to 6 psi?
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: New Best [Re: oldiron] #1629854
06/07/14 11:18 AM
06/07/14 11:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
good job, when you get traction don't be shocked if you break something out back. Good luck getting the trans worked out.
Coming soon!!!!
Re: New Best [Re: oldiron] #1629855
06/07/14 12:36 PM
06/07/14 12:36 PM
N.E. Ohio
N.E. Ohio
uh oh
Mission Creep
Congratulations!
I`m having fun just seeing what it will do right now,has already exceeded my goal.
I would need to put in a roll-bar to really go much further.
Getting a 1.56-60ft. and getting one wheel off the ground was a suprise!! 3.30 gear and stock converter??? Never would have beleived it
I am yet to understand how I doubled boost and saw no power with it.
Tried less timing/more timing/ jet/RPM no real benefit............
I am VERY happy with its road manners/driveability and would have to really think long and hard to ruin that.....
Overdrive????
Re: New Best [Re: ademon] #1629856
06/07/14 12:38 PM
06/07/14 12:38 PM
N.E. Ohio
N.E. Ohio
I can only hope mine will look that good someday. SWEET
Re: New Best [Re: 6bblFLASH] #1629857
06/07/14 02:10 PM
06/07/14 02:10 PM
uh oh
Mission Creep
Congratulations!
Overdrive????
Me thinks you have a undiagnosed problem, maybe fuel related When you jetted it up did it affect the 330 and 1/8 mile times? If so how much, better or worse? I've seen a fuel supply problem affect the 330, 1/8 mile and 1000 times but not show up in the 1/4 mile times and ET You have to look at all the numbers on the time cards for the changes, if it affects, good or bad , part of the track but not the end of the 1/4 you need to figure out why Let us know what you see on those slips, maybe we can help
Re: New Best [Re: Cab_Burge] #1629858
06/07/14 03:28 PM
06/07/14 03:28 PM
N.E. Ohio
N.E. Ohio
Hmmmm,,, except for the carb. being too small for max power. I don`t think it is supply/ AFR related.
The AFR numbers change with every fuel change.
Have made runs as rich as 11.6 to lean as 12.4
makes no difference in MPH or ET. other than it TRIES to leave harder at the leaner AFR`s.
Plugs are white-clean. Leary of trying anything leaner. But its possible thats what it wants.
But can`t get the improved power to the ground.
Pulling timing helps traction alot. So to bracket race if I pull some timing its pretty consistent.
One thing it still does that I thought was odd:
it really starts pulling at the 1,000ft. mark.
When it was doing that with the slower drive ratio I figured as did others what I`m seeing the
blower/boost is just getting to the sweet spot.
So the blower needs to turn faster.
2.23 =11,150 @5,000
2.72=13,600 @5,000 recommended MAX 14,000rpm
Even with the faster ratio I still feel it.
AFR does`nt change but you can definetly feel it start to pull near the finish line.
Re: New Best [Re: Mr.Yuck] #1629859
06/08/14 07:08 PM
06/08/14 07:08 PM
N.E. Ohio
N.E. Ohio
I have 2 fresh 727`s for the Cuda` from when I ran automatics.
Re: New Best [Re: 6bblFLASH] #1629860
06/08/14 07:48 PM
06/08/14 07:48 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Congrats Dennis!
Re: New Best [Re: 6bblFLASH] #1629861
06/08/14 08:04 PM
06/08/14 08:04 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
nice car i just bought a 69 conv
Re: New Best [Re: one bad fish] #1629862
06/08/14 10:09 PM
06/08/14 10:09 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Nice! - and you can drive it there - even better
Just remember - you have the Cuda for racing!
So leave the sawzall in the toolbox!
Re: New Best [Re: 6bblFLASH] #1629863
06/08/14 10:16 PM
06/08/14 10:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice....................with more tuning and traction, you`ll get there.
Re: New Best [Re: Thumperdart] #1629864
06/09/14 12:54 AM
06/09/14 12:54 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
As long as you have a 4 plate front clutch a stock rebuild with a manual valve body should go forever at this power level. There's a reason the high clutch has failed. Worn rings,seals,grooved drum. Find the culprit and reassemble, you'll be good to go.
Doug
Re: New Best [Re: dvw] #1629865
06/09/14 09:11 AM
06/09/14 09:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Your trans acting up could be the reason you don't see any better mph. Especially if you have sloppy shifts and are slipping in the upper rpms.
Re: New Best [Re: Mr.Yuck] #1629866
06/10/14 09:31 AM
06/10/14 09:31 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Man you're maiking me sorry I ever let that bad boy go....
Think about it, you have the power to go high tens EASILY, you just got to get it to the ground and not frag the drivetrain in doing it. If your trans is letting go gradually it's been holding you back way before then.
On my motor I had an 833 4 speed and a 3.54 Dana so I wasnt worried much about tearing the drivetrain apart....I was much more concerned about buckling the quarter panel/roof welds out of my recently restored 70 Charger R/T
Get a fresh trans and put some real slicks on it and see what it does.
WIZE
In Car:
Re: New Best [Re: Streetwize] #1629867
06/10/14 10:23 AM
06/10/14 10:23 AM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
Denny has a whole garage full of extra parts to use up before breaking stuff becomes an issue. Run it like you stole it!
Re: New Best [Re: 6bblFLASH] #1629868
06/11/14 12:11 AM
06/11/14 12:11 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Congrats Dennis. I guess they haven't thrown you out yet !
Re: New Best [Re: super451b] #1629869
06/11/14 12:58 AM
06/11/14 12:58 AM
N.E. Ohio
N.E. Ohio
After the first night they said I had to wear a jacket.
Never said anything about a rollbar yet.
So I've been wearing my SFI jacket and they have been fine with that. .....
