Re: Blower Size On Smallblock??
[Re: Blucuda413]
#1629386
06/05/14 11:32 PM
06/05/14 11:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What size blower is the largest which can reasonably be made to work on a smallblock?? Is it a 6-71, 8-71, or 10-71?? The Indy site shows a 6-71 on a sbm but they also use an offset distributor. Is the offset dizzy required? BTW would go on a 454" smallblock.
If you plan on a 454ci down the road you better think BB and base your blower on that.. if it turns less speed it makes less heat ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Cab_Burge]
#1629391
06/06/14 09:34 AM
06/06/14 09:34 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
The bigger the blower rotors the less RPM on the blower needed to make the amount(volume) boost you want, the less rotor RPM the less heat the blower makes, hot air is less dense than cooler air I'm thinking your going to need at least a 8:71 , if you could run a crank trigger ignition then a 10:71 would be even better yet
I believe it is SSI that makes a front offset blower,if you went with a 10-71 it may not be too long.I think you need an 8-71 and it would be fine.
[Re: Blucuda413]
#1629397
06/06/14 01:27 PM
06/06/14 01:27 PM
MR_P_BODY
This may sound stupid but I plan to develop both a roots blower system and a Procharger system. I have the Procharger and the installation brackets and am gradually buying all the other parts. I also have a 12-71 that I must trade for a smaller blower. For that system I have a birdcatcher for fuel. I plan to build my own manifold when I get the right size blower. My question on the roots was to figure out what size I could use without too much hassle. These are both long term projects but you have to start somewhere. BTW I need about 900hp to attain my bucket list ET of 8.99.
JMO.. but I would run either a 6-71 or a 8-71.. if you go larger on a SB it might be way too long to fit ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Clanton]
#1629399
06/06/14 02:01 PM
06/06/14 02:01 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Clanton, fuel injection with nozzles at the hat is different than running with carbs on top, then if you add the down nozzles, you can really tune for each cylinder and make the blower work a lot better. I'd be more concerned on keeping the bottom of the motor together running either style blower at the 900 - 1000 hp level on a small block.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: FastmOp]
#1629401
06/06/14 03:14 PM
06/06/14 03:14 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Use the 12 71 but mount it out front. you can intercool it and use standard intake manifolds. Plus, it would be way cooler than doing it the "standard way"
[Re: Blucuda413]
#1629403
06/09/14 02:20 PM
06/09/14 02:20 PM
Slingshot383
St. Charles, MO.
Clanton, in his second post, he said he had a bird for the roots blower, that's where I got it from.
