Blower Size On Smallblock?? #1629385
06/05/14 11:03 PM
06/05/14 11:03 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What size blower is the largest which can reasonably be made to work on a smallblock?? Is it a 6-71, 8-71, or 10-71?? The Indy site shows a 6-71 on a sbm but they also use an offset distributor. Is the offset dizzy required? BTW would go on a 454" smallblock.
Re: Blower Size On Smallblock?? [Re: Blucuda413] #1629386
06/05/14 11:32 PM
06/05/14 11:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you plan on a 454ci down the road you better think
BB and base your blower on that.. if it turns less
speed it makes less heat
Re: Blower Size On Smallblock?? [Re: Blucuda413] #1629387
06/06/14 01:06 AM
06/06/14 01:06 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Have you thought about a procharger?
Re: Blower Size On Smallblock?? [Re: SpareParts] #1629388
06/06/14 01:19 AM
06/06/14 01:19 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
must be for show....
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Blower Size On Smallblock?? [Re: Blucuda413] #1629389
06/06/14 03:58 AM
06/06/14 03:58 AM
Cab_Burge Online work
Cab_Burge  Online Work
The bigger the blower rotors the less RPM on the blower needed to make the amount(volume) boost you want, the less rotor RPM the less heat the blower makes, hot air is less dense than cooler air I'm thinking your going to need at least a 8:71 , if you could run a crank trigger ignition then a 10:71 would be even better yet
Re: Blower Size On Smallblock?? [Re: Cab_Burge] #1629390
06/06/14 06:43 AM
06/06/14 06:43 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
consider a twinscrew moves plenty of air without a huge case.
Re: Blower Size On Smallblock?? [Re: Cab_Burge] #1629391
06/06/14 09:34 AM
06/06/14 09:34 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I believe it is SSI that makes a front offset blower,if you went with a 10-71 it may not be too long.I think you need an 8-71 and it would be fine.
Re: Blower Size On Smallblock?? [Re: Clanton] #1629392
06/06/14 09:58 AM
06/06/14 09:58 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
There are two ways to go with the distributer:
They make an offset distributer for blown small block Mopar's:
http://www.moparmusclemagazine.com/techa...man_intake.html
Or a distributerless ignition:
http://www.turbo-mopar.com/forums/showthread.php?39329-Electromotive-Tec-3-laptop-progammable-DFI
Re: Blower Size On Smallblock?? [Re: Dragula] #1629393
06/06/14 10:11 AM
06/06/14 10:11 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
fits with most any distributor good for about 750Hp.
Re: Blower Size On Smallblock?? [Re: 1Fast340] #1629394
06/06/14 12:49 PM
06/06/14 12:49 PM
Alexandria, LA
Alexandria, LA
This may sound stupid but I plan to develop both a roots blower system and a Procharger system. I have the Procharger and the installation brackets and am gradually buying all the other parts. I also have a 12-71 that I must trade for a smaller blower. For that system I have a birdcatcher for fuel. I plan to build my own manifold when I get the right size blower. My question on the roots was to figure out what size I could use without too much hassle. These are both long term projects but you have to start somewhere. BTW I need about 900hp to attain my bucket list ET of 8.99.
Re: Blower Size On Smallblock?? [Re: Blucuda413] #1629395
06/06/14 01:09 PM
06/06/14 01:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd just use what you have. 12-71 is not unheard of on a blown alcy 454.
You better have a big Procharger if your trying to compair the two.
Re: Blower Size On Smallblock?? [Re: FastmOp] #1629396
06/06/14 01:24 PM
06/06/14 01:24 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
A f2 would compair easily with that. There is a f2 on this board that goes 4.70s at over 3300 lbs on a bbm.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Blower Size On Smallblock?? [Re: Blucuda413] #1629397
06/06/14 01:27 PM
06/06/14 01:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
JMO.. but I would run either a 6-71 or a 8-71.. if
you go larger on a SB it might be way too long to
fit
Re: Blower Size On Smallblock?? [Re: Blucuda413] #1629398
06/06/14 01:36 PM
06/06/14 01:36 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
here is some info that may help you decide.My 8-71 take about 70/90 hp to drive at 10%OD with 240*F air temps and I have read that a 10-71 at lets say 6%OD to make the same hp was 20*F cooler IAT and that 20*F cooler temp make 20 more hp +/- 5 I would say.
Re: Blower Size On Smallblock?? [Re: Clanton] #1629399
06/06/14 02:01 PM
06/06/14 02:01 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Clanton, fuel injection with nozzles at the hat is different than running with carbs on top, then if you add the down nozzles, you can really tune for each cylinder and make the blower work a lot better. I'd be more concerned on keeping the bottom of the motor together running either style blower at the 900 - 1000 hp level on a small block.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Blower Size On Smallblock?? [Re: Slingshot383] #1629400
06/06/14 02:13 PM
06/06/14 02:13 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I did not see where he said it was injected!I was also waiting to find out what block he has.
Re: Blower Size On Smallblock?? [Re: FastmOp] #1629401
06/06/14 03:14 PM
06/06/14 03:14 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Use the 12 71 but mount it out front. you can intercool it and use standard intake manifolds. Plus, it would be way cooler than doing it the "standard way"
Re: Blower Size On Smallblock?? [Re: TRENDZ] #1629402
06/07/14 01:41 PM
06/07/14 01:41 PM
Alexandria, LA
Alexandria, LA
TRENDZ, the old Potvin kit trick. It's been a long time since I've seen one of those. Good idea but no space. Is anyone currently using a 8-71 on a small block and if so what manifold and how much clearance between blower and distributor??? Thanks, Max
Re: Blower Size On Smallblock?? [Re: Blucuda413] #1629403
06/09/14 02:20 PM
06/09/14 02:20 PM
St. Charles, MO.
St. Charles, MO.
Clanton, in his second post, he said he had a bird for the roots blower, that's where I got it from.
Re: Blower Size On Smallblock?? [Re: Slingshot383] #1629404
06/09/14 08:22 PM
06/09/14 08:22 PM
ohio
Sherminator Offline
Sherminator  Offline
ohio
wow
