8 3/4 AXLE CARNAGE......................... #1628751
06/04/14 06:47 PM
06/04/14 06:47 PM
State of confusion
Thumperdart Offline OP
State of confusion
Now that I have your attention; No, it didn`t blow YET but was curious about which let`s go first...........gears or axles. I`m assuming gears cos my 30 spline Dutchman`s look damn near perfect after many years of street/strip bashing and rerely hear about 8 3/4 axles lettin go it`s usually the cap/gears. Hopefully I have two more races lined up this Sunday but don`t want to be TOO confident just yet just because the axles look great................
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628752
06/04/14 06:55 PM
06/04/14 06:55 PM
an8sec70cuda Offline
After I broke the suregrip running mid 11s, I put in a spool and 35 spline Moser axles. Broke the ring and pinion when I got into the mid 10s.
A good axle is a good axle...doesn't make much difference what rear it's in.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8 3/4 AXLE CARNAGE......................... [Re: an8sec70cuda] #1628753
06/04/14 07:03 PM
06/04/14 07:03 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
The two that I have seen break. Pushed the caps back. One was a stick car the other was a b_body auto.
Re: 8 3/4 AXLE CARNAGE......................... [Re: rt66jim] #1628754
06/04/14 07:19 PM
06/04/14 07:19 PM
Once you have good axles and a spool in most 8 3/4 the left side(drivers side) bearing cap becomes the weak link Now is the time to address that before it breaks and wrecks the ring and pinion I have two in stock, call me Dom
Re: 8 3/4 AXLE CARNAGE......................... [Re: Cab_Burge] #1628755
06/04/14 07:31 PM
06/04/14 07:31 PM
State of confusion
State of confusion
That`s what I thaught but had to ask..............I`ll call ya Cab unless I decide to go a different route........
Re: 8 3/4 AXLE CARNAGE......................... [Re: Cab_Burge] #1628756
06/04/14 08:07 PM
06/04/14 08:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
But if you do it have it done right. The new caps have to be properly fitted, and the lash screwed back to where it needs to be.
Ive seen where people have had rears stay together as was, but blow up after changes to strengthen it because of improper fitment of the new caps. Mostly, the caps ending up to loose allowing lash to get sloppy and push out the retainers and boom.
Re: 8 3/4 AXLE CARNAGE......................... [Re: Sport440] #1628757
06/04/14 08:30 PM
06/04/14 08:30 PM
Utah
topbrent Offline
topbrent  Offline
Utah
You didn't ask and probably don't want to hear it, but.....
Why keep pushing your luck with that poor 8-3/4?
You know you are going to kill the thing. Sooner rather than later and probably with catastrophic results.
Sell it now while it is still in one piece and worth something.
A basic, cut down Dana with a spool isn't that expensive if you reuse your brakes.
Sutton Engineering is a good source reasonably close to you.
- Complete Dana 60 with a Moser spool and 35-spline axles = $1400.00
Re: 8 3/4 AXLE CARNAGE......................... [Re: topbrent] #1628758
06/04/14 08:34 PM
06/04/14 08:34 PM
State of confusion
State of confusion
I hear ya and I will step up soon just not in the finances today.............
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628759
06/04/14 08:58 PM
06/04/14 08:58 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I broke the cap first in my Demon. I put a billet cap on it then it broke the gear.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 8 3/4 AXLE CARNAGE......................... [Re: D-50] #1628760
06/04/14 09:06 PM
06/04/14 09:06 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Should I ask where the races are being held?,, did the Vette get his auto in the car?
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 8 3/4 AXLE CARNAGE......................... [Re: johnnycuda] #1628761
06/04/14 11:10 PM
06/04/14 11:10 PM
State of confusion
State of confusion
Out by you............wink wink.............He`s not one of the races and no, he hasn`t done the swap yet. Nitrous late model Pontiac on spray iirc and a 70 240-Z on spray.............
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628762
06/04/14 11:43 PM
06/04/14 11:43 PM
geezer acres rest home
dakotawilly Offline
dakotawilly  Offline
better get your aaa plus membership,so you can get that free tow....
SFI 25.5 depends,no leak,even at 213 mph....
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628763
06/05/14 12:23 AM
06/05/14 12:23 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
My feelings are that you are not going to hit that gear hard enough on the street. We had 30 spline Dutchman's in the Duster and were twisting splines pretty hard. All track time, mostly t-brake launches. Switched to a D-60 before we really did some damage.
Re: 8 3/4 AXLE CARNAGE......................... [Re: J_BODY] #1628764
06/05/14 12:51 AM
06/05/14 12:51 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
This showed up today....Thanks Cass
Tony
70 AARCuda Vitamin C
Re: 8 3/4 AXLE CARNAGE......................... [Re: J_BODY] #1628765
06/05/14 01:44 AM
06/05/14 01:44 AM
State of confusion
State of confusion
I`m hopein it holds just a bit longer till I make an upgrade.............Man that`s a nice Dana.............
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628766
06/05/14 01:53 AM
06/05/14 01:53 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Hell, everyone knows you can't break an 8 3/4, the best rear end made .
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628767
06/05/14 01:59 AM
06/05/14 01:59 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
As has been covered MANY times, good axles, caps, backbraces and all that other stuff will NOT fix the weakness of the case that LETS the ring and pinion push apart and kills gears. Sure the cap helps, but think WHY. The pinion is trying to roll the ring gear out of the housing and breaks the stock cap. So you put a GOOD cap on it and now the case has to try and shoulder all the deflection and it can't. You CAN'T fix that or patch it up.........BUT, the car may NEVER hook hard enough on the street to break it, but then it may break on the next hit. THAT is the problem. You KNOW it's coming, just never know when. Probably would have already broken it if you ran at the track a lot. Likely be wise to start buying up some Dana stuff now if that is what you want.
Monte
Re: 8 3/4 AXLE CARNAGE......................... [Re: Monte_Smith] #1628768
06/05/14 02:22 AM
06/05/14 02:22 AM
State of confusion
State of confusion
Wish I could swing the bad dog chromeoly 9 in. but maybe someday. Just may end up w/a Dana after all for the $$$.............
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628769
06/05/14 02:26 PM
06/05/14 02:26 PM
johnnycuda Offline
johnnycuda  Offline
Hey Dom, let me know if you can of the time and place, maybe I can show up and watch.
Re: 8 3/4 AXLE CARNAGE......................... [Re: Thumperdart] #1628770
06/05/14 02:45 PM
06/05/14 02:45 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Dom, pushing the envelope is fine sometimes. A buddy of mine had his 8 3/4 in an A body cough its guts at about 10.80's. It sucked because it also caused a ton of transmission damage when it let go.
There's no generic GM's or Nissans worth a new rear and a trans....
...FAFO...
