Re: 8 3/4 AXLE CARNAGE.........................
[Re: Thumperdart]
#1628752
06/04/14 06:55 PM
06/04/14 06:55 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
After I broke the suregrip running mid 11s, I put in a spool and 35 spline Moser axles. Broke the ring and pinion when I got into the mid 10s.
A good axle is a good axle...doesn't make much difference what rear it's in.
[Re: Cab_Burge]
#1628756
06/04/14 08:07 PM
06/04/14 08:07 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
The two that I have seen break. Pushed the caps back. One was a stick car the other was a b_body auto.
Once you have good axles and a spool in most 8 3/4 the left side(drivers side) bearing cap becomes the weak link Now is the time to address that before it breaks and wrecks the ring and pinion I have two in stock, call me Dom
But if you do it have it done right. The new caps have to be properly fitted, and the lash screwed back to where it needs to be.
Ive seen where people have had rears stay together as was, but blow up after changes to strengthen it because of improper fitment of the new caps. Mostly, the caps ending up to loose allowing lash to get sloppy and push out the retainers and boom.
[Re: Sport440]
#1628757
06/04/14 08:30 PM
06/04/14 08:30 PM
Posts: 793 Utah
topbrent
Utah
You didn't ask and probably don't want to hear it, but..... Why keep pushing your luck with that poor 8-3/4? You know you are going to kill the thing. Sooner rather than later and probably with catastrophic results. Sell it now while it is still in one piece and worth something. A basic, cut down Dana with a spool isn't that expensive if you reuse your brakes. Sutton Engineering is a good source reasonably close to you. - Complete Dana 60 with a Moser spool and 35-spline axles = $1400.00
[Re: Thumperdart]
#1628759
06/04/14 08:58 PM
06/04/14 08:58 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I broke the cap first in my Demon. I put a billet cap on it then it broke the gear.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1628760
06/04/14 09:06 PM
06/04/14 09:06 PM
Posts: 860 lancaster,california
johnnycuda
Should I ask where the races are being held?,, did the Vette get his auto in the car?
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: J_BODY]
#1628764
06/05/14 12:51 AM
06/05/14 12:51 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
This showed up today....Thanks Cass
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Thumperdart]
#1628769
06/05/14 02:26 PM
06/05/14 02:26 PM
johnnycuda
Hey Dom, let me know if you can of the time and place, maybe I can show up and watch. Quote:
Out by you............wink wink.............He`s not one of the races and no, he hasn`t done the swap yet. Nitrous late model Pontiac on spray iirc and a 70 240-Z on spray.............
