Best intake manifold to use with 1970 coronet with 440? #1628463
06/04/14 04:35 AM
06/04/14 04:35 AM
Fredonia, NY
diesel Offline OP
diesel  Offline OP
Fredonia, NY
Hello. I have a 1970 coronet convertible with a 440. She currently has an Edelbrock Performer 440 intake manifold installed. The problem with this manifold is that its height is too tall for me to use my air grabber air cleaner. Although I do not currently have the duct work or scoops installed yet, I would like to be able use the air cleaner for now. Thank you for your help in advance.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628464
06/04/14 07:12 AM
06/04/14 07:12 AM
Campbellsport, Wisconsin
Abodysforever Offline
I believe a Mopar M1 has close to a stock height.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628465
06/04/14 10:41 AM
06/04/14 10:41 AM
an8sec70cuda Offline
I assume you mean you have the Edelbrock Performer RPM? The Performer is a stock height, stock replacement dual plane. The Performer RPM is a tall "high-rise" dual plane w/ a cut down divider that makes way more power.
There are a few different M1 manifolds too. The M1 dual plane is just an aluminum version of the factory magnum manifold. The M1 single plane is about as tall as the RPM and available w/ either the 4150 or 4500 flange.
I have no experience w/ how tall of a manifold you can use w/ the air grabber set up, but I bet you can't get away w/ much taller than stock.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best intake manifold to use with 1970 coronet with 440? [Re: an8sec70cuda] #1628466
06/04/14 10:53 AM
06/04/14 10:53 AM
Georgia
Steve Bryant Offline
Georgia
So I used an Edelbrock Performer (not RPM) on my 440 and I think it is a tad taller than the factory manifold but it clears fine in my Cuda even with a rubber carb spacer.
Sure you don't have an RPM? As a9sec70cuda stated, the RPM is noticeably taller and it is a single plane.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: Steve Bryant] #1628467
06/04/14 12:00 PM
06/04/14 12:00 PM
The Performer RPM is not a single plane.
As far as good street manifolds go, the Edelbrock Performer RPM and the Holley Street Dominator are about the best there is for a fairly mild engine. The Holley SD is much shorter than the RPM, so I doubt it would work w/ the air grabber setup either.
CHIP
Re: Best intake manifold to use with 1970 coronet with 440? [Re: Steve Bryant] #1628468
06/04/14 12:33 PM
06/04/14 12:33 PM
Fredonia, NY
diesel Offline OP
diesel  Offline OP
Fredonia, NY
Thank you for your responses so far. It just says performer 440 on the intake. I am attempting to post a picture of it for you to look at. I want to keep at least the same performance or improve while still being able to use my air cleaner setup. This silly little air cleaner I have on it now is ridiculous.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: an8sec70cuda] #1628469
06/04/14 12:36 PM
06/04/14 12:36 PM
Georgia
Georgia
DOOH, sorry I am pain meds this morning. I meant that the RPM IS a single plane and the Performer is a split plane.
I went with the Performer because I was looking for a better flow, cooler manifold temp and I wanted me power lower in the RPM range. Plus, it looks pretty close to factory.
If you are looking to get your power with lower RPMs then the Performer is a great manifold.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628470
06/04/14 12:47 PM
06/04/14 12:47 PM
Wow, I'm surprised that intake is too tall to work w/ the air grabber setup. The only manifolds that are shorter than what you currently have will be the Mopar Performance M1 dual plane (which is aluminum) or a factory stock cast iron manifold.
The m1 dual plane looks like this...
http://chucker54.stores.yahoo.net/383400duelpl.html
Only that one is for a 383/400 low deck. Not sure if they even make the RB version of this manifold anymore?
I've seen the RB versions pop up on ebay from time to time.
PM sent about factory manifolds.
CHIP
Re: Best intake manifold to use with 1970 coronet with 440? [Re: Steve Bryant] #1628471
06/04/14 12:50 PM
06/04/14 12:50 PM
LOL, the Performer AND the Performer RPM are BOTH dual plane manifolds.
The Performer saves you some weight over the factory iron piece, but very little as far as performance increase.
The Performer RPM is a VERY good manifold, just too tall for a lot of applications. Makes a lot of lowend grunt along w/ good upper rpm power.
The Holley SD has almost all the same characteristics of the Performer RPM (good lowend torque and drivability as well as good upper rpm power) even though it is a single plane and is a shorter manifold.
CHIP
Re: Best intake manifold to use with 1970 coronet with 440? [Re: an8sec70cuda] #1628472
06/04/14 01:40 PM
06/04/14 01:40 PM
I totally agree. The SD is very short & works fairly well on the low end for being a single plane. No longer available new for an RB iirc but they are around. I hear there are better absolute choices but it works well for what it is & if you need the clearance...
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628473
06/04/14 02:10 PM
06/04/14 02:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This manifold may be maybe a 1/4 to 1/2 " taller than the stock cast iron 440 intake.
The only way you are going to get ANY manifold that is taller than the stock cast iron manifold on there is to modify the air cleaner base .
Re: Best intake manifold to use with 1970 coronet with 440? [Re: JohnRR] #1628474
06/04/14 02:38 PM
06/04/14 02:38 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Holley Street Dominator.They work and will fit.Plus you can find RB ones used at a decent price.I quit using Eddys about 20 years ago.Seems every one didnt quite fit just right.All the Holleys I used just dropped on.Rocky
Chrysler Firepower
Re: Best intake manifold to use with 1970 coronet with 440? [Re: therocks] #1628475
06/04/14 02:52 PM
06/04/14 02:52 PM
dogdays Offline
dogdays  Offline
Street Dominator is available new, you could look it up.
http://www.summitracing.com/parts/hly-300-14/overview/make/dodge
BUT, I agree with the other posts. If your Performer is too tall, you are SOL. It's about as short as any non-stock intake.
That's why they make drop bases for air cleaners.
R.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: dogdays] #1628476
06/04/14 04:41 PM
06/04/14 04:41 PM
Fredonia, NY
diesel Offline OP
diesel  Offline OP
Fredonia, NY
I looked at the street dominator from the link (thank you) but it doesn't seem to say how tall it is. So, I guess I'm basically SOL like you said. I don't see how I would modify this base, nor do I think I should before it comes time to mount the new hood with the scoops and ductwork and see how it fits then. Unfortunately I won't be able to do that until possibly next year or the year after. A drop base would be great, do they make one for an air grabber? lol If anyone else has any other ideas, I'd love to hear them. Thank you again to all that have responded thus far.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628477
06/04/14 05:00 PM
06/04/14 05:00 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Have you checked you air grabber breather to make sure it is a 440 one? The 383 base is taller than the 440 one. If you have a 383 one mounted on your 440 that would give you clearance problems. Easiest way to tell is set it on a table and if it rocks it is a 383. If not it is a 440. Worth a try
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Best intake manifold to use with 1970 coronet with 440? [Re: MOPARMIKE69] #1628478
06/04/14 05:17 PM
06/04/14 05:17 PM
Houston, Texas
Slant6pak Offline
Slant6pak  Offline
Houston, Texas
The old Edelbrock CH4B may fit as well.
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628479
06/04/14 08:48 PM
06/04/14 08:48 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Order of height from shortest to tallest:
Factory and M1 dual plane
CH4B
Performer
Holley SD
Indy 440 2D
Performer RPM.
If your engine is mild, I would recommend staying with factory to the Performer.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: BSB67] #1628480
06/04/14 10:52 PM
06/04/14 10:52 PM
Central NC
gch Offline
gch  Offline
Central NC
I believe there was an old article that stated the Weiand Action Plus was about the right height for an air grabber setup.The ch4b may be a close fit and it is an all around better intake than the Weiand.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: MOPARMIKE69] #1628481
06/05/14 03:58 AM
06/05/14 03:58 AM
Fredonia, NY
diesel Offline OP
diesel  Offline OP
Fredonia, NY
I checked the base and it sits steady on a table. It was also marked by the seller as a 440 baseplate. I was hoping that it was the wrong part thus fixing the problem. The lid was marked by the seller as a 383 lid though... are there any differences in lid heights? I never knew there was any height difference for a 383 and 440 air grabber, so it never occurred to me that the lid or base could be the problem. The engine in the car is a mild build and seems to like the performer that is currently on her, is there a noticeable performance difference between the m1 dual plane or CH4B and the performer thats currently on her? I would be seriously considering the M1 if it is the factory height as it should definitely fix the problem?? The hood will close with just the baseplate on but once you add the filter and lid,a definite no go. So I believe I need maybe an inch or lil more clearance because the filter doesn't sit very high. I again wish to thank everyone who is sharing their opinions and knowledge.
Re: Best intake manifold to use with 1970 coronet with 440? [Re: diesel] #1628482
06/05/14 09:58 AM
06/05/14 09:58 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Yes the 383 base is taller but there isn't any difference in the lids height.You can get different air filters that have different heights. I have an M1 on my RR and I have no clearance problems.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
