Planning on putting 5.9 efi into a 57 wagon. Help me #1628389
06/04/14 01:23 AM
06/04/14 01:23 AM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
I have a 57 dodge seirra wagon that I want to put a 97 5.9l in. I bought the motor/trans and motor wire harness and computer tonight. I know this kind of swap has happened for all kinds of muscle cars. But what I need info on is how to make the power steering stuff compatible? What fuel pump is needed? Do I need to upgrade the orig 12v on the wagon. Any other info would be appreciated!
"Think of all the Ford owners who will someday want an automobile." John Dodge
57 dodge sierra wagon
03 chrysler 300m
10 dodge charger
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Biggie] #1628390
06/04/14 11:04 AM
06/04/14 11:04 AM
Buckeye Lake
56_Royal_Lancer Online content
My Mouth Is Shut II
56_Royal_Lancer  Online Content
My Mouth Is Shut II
Buckeye Lake
There is a hot rodding forum on www.forwardlook.net that may be helpful. Good luck, that's a cool project.
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: 56_Royal_Lancer] #1628391
06/04/14 04:53 PM
06/04/14 04:53 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
Thanks! I've tried using the search on that site but its not showing any results. Must not be typing in right thing
03 chrysler 300m
10 dodge charger
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Biggie] #1628392
06/04/14 05:09 PM
06/04/14 05:09 PM
Buckeye Lake
My Mouth Is Shut II
My Mouth Is Shut II
Buckeye Lake
Here is a link to the hot rod forum, if you don't see the topic there start a new thread. I got some good info from there when I was working on my '56.
http://www.forwardlook.net/forums/forums/forum-view.asp?fid=7
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: 56_Royal_Lancer] #1628393
06/11/14 05:50 PM
06/11/14 05:50 PM
Finland
mafo Offline
mafo  Offline
Finland
I have a 5.2 in my 55 Dodge, cant help you with the power steering but
the rest I have pretty good sorted
I use a Walbro inline pump but if I do it again I ll go with a in tank pump
I believe the 5.9 needs a fuel pressure regulator , I have heard that there is a GM product that works, fuel regulator/filter from a corvette, if you can use one of those on your car that is...
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: mafo] #1628394
06/11/14 09:27 PM
06/11/14 09:27 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
I think we are going to put in a rack and pinion for steering.
Why would you go with an in tank fuel pump? My gas tank has holes in the bottom so I was going to have a local shop bend up material to match orig tank and then we will weld it up. So at this point we are open to what we do,
I would rather keep it mostly mopar but I doubt too many people will be looking at my gas tank. Would the corvette parts make my car worth more?
03 chrysler 300m
10 dodge charger
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Biggie] #1628395
06/12/14 05:23 AM
06/12/14 05:23 AM
Finland
mafo Offline
mafo  Offline
Finland
In tank pump because it s quiet, no other reasons
if you are going with a rack and pinion, I m afraid you need some more GM parts, I have one from a cavalier that I m going to use on my car, don t know when since it works good with the manual steering but it s in the plans
There is a kit for 55 ford that is very similar, going to copy that one
I cant remember the manufacturer but I bet google can help you
Here is some pics of my tank
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
and, Yes corvette parts will at least double the value of your car
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: mafo] #1628396
06/12/14 10:02 AM
06/12/14 10:02 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
In tank fuelpumps are cooled by the fuel around it. Makes them live longer.
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: BigBlockMopar] #1628397
06/12/14 01:03 PM
06/12/14 01:03 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
Alright I will go with the in tank then. Obviously the one from 97 would have to modified. Are those pumps submerged at the bottom of tank? Reason I ask is my orig tank is tall so if I can buy just a pump I need to know if I need to mount pump at top or bottom of tank
03 chrysler 300m
10 dodge charger
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Biggie] #1628398
06/12/14 01:32 PM
06/12/14 01:32 PM
Finland
mafo Offline
mafo  Offline
Finland
Try to get the complete assembly to fit, there is a lot to chose from
something like this maybe
http://www.fuelpumps.com/chrysler-fuel-p...edan-p-746.html
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Biggie] #1628399
06/12/14 02:50 PM
06/12/14 02:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This in-tank pump is popular with rodders. Scroll down to the PDF instructions to see if it'll work with your setup.
http://www.summitracing.com/parts/aei-18688
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: John_Kunkel] #1628400
06/13/14 12:27 AM
06/13/14 12:27 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Anyone know the depth of a fuel tank for a 97 Dodge full size pickup? The tank Biggie has/will need to build is in a wagon quarter panel. We are restricted to width & length, so the puts the height in the 15" range. The tank he has is junk, so building a tank is probably what we will end up doing.
For those of you that have built tanks, what did you used for material, and what gauge (thickness) was the material you used?
And while I'm asking dumb questions, if we should use a factory replacement fuel pump with the plastic housing, do we still need to add the reservoir to the bottom of the tank? Gene
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: poorboy] #1628401
06/13/14 04:18 AM
06/13/14 04:18 AM
Finland
mafo Offline
mafo  Offline
Finland
I did mine from 2 mm aluminum,stainless may be a better choice
If you use the complete pump you don t need anything else
I measured a pump from a -05 pickup and it adjust from 10" to 14.5",
don t know about the -97
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: mafo] #1628402
06/13/14 11:02 PM
06/13/14 11:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Better make sure that in tank pump is baffled since fuel will slosh away from it and kill the engine otherwise, BTDT.
Don't be the exception.
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Supercuda] #1628403
06/13/14 11:24 PM
06/13/14 11:24 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
What do you mean by "the pump has to be baffled"? Is there something we would have to have in addition to the plastic that usually surrounds the pump? Gene
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: poorboy] #1628404
06/14/14 07:16 AM
06/14/14 07:16 AM
Finland
mafo Offline
mafo  Offline
Finland
If you use the stock plastic housing you don t need baffles, the tank in my -05 pickup is like 5 foot long and have nothing inside...but some kind of baffle or wall inside may be a good idea, just for support
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: poorboy] #1628405
06/14/14 08:08 AM
06/14/14 08:08 AM
moparx Offline
moparx  Offline
gene, I've done 2 tanks. the one was for a 55 chevy. for it, I used a section of a wrecked Pontiac tank for the sump and mounting ring area, which allowed the use of a factory pump. this was welded into the 55 tank. the sump was a round area[a can shape the pump fits down into] with just a couple of smallish slots to allow fuel to enter and had a couple of locator/support tabs on the bottom that braced the pump when it was installed. this is to supplement the "basket" that surrounds the factory pump assembly. this was to feed a 94 LT1 that is stock. if I remember right, this pump is used in a bunch of gm vehicles, so replacements are everywhere. the other was for my cousin's 29 model A rpu. for it, 14ga. flat stock was used. it was bent up into a box shape with the sending unit/pickup/filler neck areas marked and cut out before it was bent. as this was just a "square-ish" type tank, 2 baffels were cut and welded into the inside before the ends were welded on. remember to pressureize the finished tank with about 10lbs of air to check for leaks. there are bound to be several if your luck is like mine. when both tanks held 10lbs. for a week or so, they were installed, and both have been trouble free. if you can, stainless would be the best material to use if it's available because of todays gas. if I remember correctly, the factory uses a special coating on the steel tanks, but I can't remember the name of it. hope this helps in your decision.
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: moparx] #1628406
06/14/14 10:17 AM
06/14/14 10:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
terne coated, you pretty much hit the baffle idea right on the head. When I EFI'd my 87 Diplomat I put a pump on the end of the stock pickup. That did not work well.
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Supercuda] #1628407
06/15/14 05:01 PM
06/15/14 05:01 PM
NW IL
Biggie Offline OP
Biggie  Offline OP
NW IL
We got some work done yesterday. Pulled the front clip off and the 325 poly with transmission out. Couldn't believe it. Didn't brake a single bolt!
Looks like the original motor mounts will work on the magnum. Just from quick measurements it doesn't look like we will have to modify the trans tunnel. Maybe the mount but that's not a big deal. We will have to do some engineering work for the rack and pinion. We have an intrepid rack that we will use for mock up but will end up using a gm rack.
03 chrysler 300m
10 dodge charger
Re: Planning on putting 5.9 efi into a 57 wagon. Help me [Re: Biggie] #1628408
06/16/14 02:07 AM
06/16/14 02:07 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We measured an extra fuel tank (we have 3 tanks, all with holes rusted in them) from a wagon tonight. The wagon tank is 20" deep, top to bottom, and about 20" square sides with a width of about 10".
Installing a modern in tank fuel pump will be an interesting project if we have to come in from the top. Are there options where we might be able to come in from one end or from the side with a pump that sits at 90 degrees? How about, since the bottom of the tank is only 10" wide (side to side) and about 20" long (front to back) will we have a problem if we attach the efi pump to the wagon sending unit and let it hang just off the bottom of the tank? We can add front and rear baffles about 6" high off the tank bottom on both sides of the hanging pump, will that work? I figure we are going to have to add at least on baffle to prevent fuel movement front to back, so it wouldn't be a big deal to add a second one on the other side of the pump. I figured we would have a piece of steel formed across the top, bent down the inside, bent across the bottom, then bent back up the outside. We would have a weld seam across the top, and on both ends + on the sides of whatever we put inside for baffles. We will probably have to round the top rear corner to fit in the car. We would have the fuel pump/fuel pickup & sending unit and a fill hole on the top surface of the tank.
The thing that will suck is that the tank will have to come out to replace he fuel pump.
Think the hanging efi pump with front and rear baffles will be good enough that we won't have an issue? Gene
