Throw out bearing rotating in clutch fork. #1628051
06/03/14 09:42 AM
06/03/14 09:42 AM
Auburn Mich.
5.7bob Offline OP
5.7bob  Offline OP
Auburn Mich.
I moved the fork in but it still wants to rotate under heavy load. A buddy said he heard use a Ford bearing. Any ideas.
Re: Throw out bearing rotating in clutch fork. [Re: 5.7bob] #1628052
06/03/14 12:16 PM
06/03/14 12:16 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
There are clips that secure the throw out bearing in the fork. Are they missing or broken?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Throw out bearing rotating in clutch fork. [Re: MOPARMIKE69] #1628053
06/03/14 10:29 PM
06/03/14 10:29 PM
Auburn Mich.
5.7bob Offline OP
5.7bob  Offline OP
Auburn Mich.
They are there and not broken.
Re: Throw out bearing rotating in clutch fork. [Re: 5.7bob] #1628054
06/05/14 03:49 AM
06/05/14 03:49 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Check if the part named pivot is cracked or misshaped. That happened to me - the pivot does not seem to be strong enough. The fork has a riveted flat retaining spring that is engaged in a hole in the pivot. The pivot is bolted to the back of the bell housing with two screws.
If the pivot is bad, make your own out of heavier material.
Re: Throw out bearing rotating in clutch fork. [Re: kentj340] #1628055
06/05/14 04:47 AM
06/05/14 04:47 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I repaired a bent pivot that eventually broke due to flexing, because the guy bent it so he could pull the shift fork out and put it back in. It flexed enough that it finally broke and left us stranded in a nearby town. I made a small relief in the bell housing opening for the shift fork with a carbide burr, so it would fit in and hook to the replacement pivot without having to bend it to get it back in the bellhousing with both clips securely attached. Luckily, I happened to have a spare one in my parts stash.
Re: Throw out bearing rotating in clutch fork. [Re: jbc426] #1628056
06/05/14 09:10 AM
06/05/14 09:10 AM
Auburn Mich.
5.7bob Offline OP
5.7bob  Offline OP
Auburn Mich.
I took the fork out yesterday put some tacks on the inside edges of the fork and filed it. There was to much gap there. Did some heavy testing and it did not turn in the fork. Life is good now.
