Steering Wheel Column Nut
#1627435
06/01/14 10:24 PM
06/01/14 10:24 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Where can I source one of these? For the Dart... I can't find mine, it has to be somewhere, sure it will show up after I get another.
Are these a thinner jam nut, lock nut, or? I know the size is 9/16-18 fine thread.
Thanks!
383, Hemi 4-Speed, AlterKtion, D60
Re: Steering Wheel Column Nut
[Re: Crazy68Dart]
#1627436
06/02/14 02:09 AM
06/02/14 02:09 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I don't think its a lock nut. At least in 1956 they weren't ![](/ubbthreads/images/graemlins/laugh.gif) I seem to remember a washer with groves for locking under the nut (?) but its been many years. Anyway, I had to make one for an old Dodge 1/2 ton. I found a nut of the proper thread configuration and had it split to the right thickness (on an industrial bandsaw *only because they had one where I worked that could slice a .06" wafer from a piece only an inch long*) ![](/ubbthreads/images/graemlins/whistling.gif) A carefully wielded hacksaw and a vise would work too in a pinch ![](/ubbthreads/images/graemlins/thumbs.gif) Scott
[Re: Scott Carl]
#1627437
06/02/14 11:28 AM
06/02/14 11:28 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
I would think there would be plenty in a junk yard, it is a lock nut on most everything I have seen. Surely another member in the area has one to give you, if not I can put one in the mail in the next few days, PM me if it becomes necessary.
Careful, your character's showing!
[Re: mopar346]
#1627438
06/03/14 03:55 PM
06/03/14 03:55 PM
Crazy68Dart
Canton, Ohio
I might call the dealer.... I can source a 9/16 - 18 nut anywhere. Does the FSM have a good shot of the nut?
[Re: azmopar]
#1627440
06/03/14 06:56 PM
06/03/14 06:56 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Put a nut on with blue LockTite.Red if you are paranoid.Ive never seen a washer under any of the wheels Ive pulled and I pulled a lot.Once the wheel is tightened the nut is pretty much just a second safety.Try pulling a wheel off without a puller.Rocky
Chrysler Firepower
