High Helix Littlefield 14:71 #1627379
06/01/14 06:44 PM
06/01/14 06:44 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Are there intakes for a 440 that fits?
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: High Helix Littlefield 14:71 [Re: fed] #1627380
06/02/14 05:49 PM
06/02/14 05:49 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Anyone?
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: High Helix Littlefield 14:71 [Re: fed] #1627381
06/02/14 06:42 PM
06/02/14 06:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Indy makes one. It's about $800 but they prolly have it in stock.
Re: High Helix Littlefield 14:71 [Re: FastmOp] #1627382
06/02/14 06:58 PM
06/02/14 06:58 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Is that the Modman intake that Indy offer?
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: High Helix Littlefield 14:71 [Re: fed] #1627383
06/02/14 07:09 PM
06/02/14 07:09 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
They had one before the mod man stuff but I'd call.
Re: High Helix Littlefield 14:71 [Re: FastmOp] #1627384
06/02/14 10:16 PM
06/02/14 10:16 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That a pic of the blower? It looks smaller then a 14-71
Re: High Helix Littlefield 14:71 [Re: FastmOp] #1627385
06/03/14 03:08 PM
06/03/14 03:08 PM
Stockholm, Sweden
fed Offline OP
fed  Offline OP
Stockholm, Sweden
Thinking of buying, supposed to 14/71
Cuda, -70
Valiant-65 AWB,
NostalgiaFED Sold,
Re: High Helix Littlefield 14:71 [Re: fed] #1627386
06/03/14 03:26 PM
06/03/14 03:26 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Looks better from that angle.
If they remove it from that intake get a pic of the rotors.
Re: High Helix Littlefield 14:71 [Re: fed] #1627387
06/03/14 03:41 PM
06/03/14 03:41 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
It looks to be the standard blower base stud pattern. The issue will be, if its a true Hi-helix, is that it will probably have the triangular pie-shaped bottom opening toward the front instead of a full length opening, and depending on the manifold design may direct more of the fuel/air charge into the front of the manifold. That's why you see a lot more set-back blower setups, they are trying to locate the opening of the blower more toward the center of the intake manifold to even the fuel distribution.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: High Helix Littlefield 14:71 [Re: 23T Hemmee] #1627388
06/03/14 10:58 PM
06/03/14 10:58 PM
I had Littlefield open up the bottom on my 14-71 to decrease this issue, it now has two pie openings.
Re: High Helix Littlefield 14:71 [Re: 23T Hemmee] #1627389
06/04/14 10:36 AM
06/04/14 10:36 AM
New York
polyspheric Offline
polyspheric  Offline
New York
All clocked (rotated lobe) blowers direct more charge into the front of the manifold.
The better ones compensate for this with a triangular discharge port, the worse ones don't.
The sides of the triangle generally follow the rotor angle.
Important: references to "helix angle" are not the angle of the rotors, it's the number of degrees of twist the rotors make front to back. A 10" long "60° helix" rotor will have twice the angle as a 20" rotor, etc.
This is one reason why rotor swaps between different Eaton M-series sizes aren't more successful...
Boffin Emeritus
Re: High Helix Littlefield 14:71 [Re: 23T Hemmee] #1627390
06/04/14 11:55 PM
06/04/14 11:55 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am using a delta opening from The Blower shop with a BDS intake and yes it feeds to the front but I also have an intercooler that corrects that now for the most part.
Re: High Helix Littlefield 14:71 [Re: 23T Hemmee] #1627391
06/05/14 08:36 AM
06/05/14 08:36 AM
SW WI
cudacustoms1 Offline
SW WI
If you end up with an indy manifold it can be turned around backwards with slight mods and you will gain 3 5/8 set back . It will help with the uneven distibution problem alittle. Yes I have run one this way and it will work.
