Best way to lower my 77 dodge van? #1626543
05/29/14 04:05 PM
05/29/14 04:05 PM
ME
79machocharger Offline OP
ME
Just wondering what my best bet is to lower my van down some. I don't want it slammed but just need to come down some so it's not so jacked up. I've got some keystones going on it this weekend and I just wanted to get it sitting on them nicely.
Thanks for any help.
Re: Best way to lower my 77 dodge van? [Re: 79machocharger] #1626544
05/29/14 04:06 PM
05/29/14 04:06 PM
ME
ME
rear
Re: Best way to lower my 77 dodge van? [Re: 79machocharger] #1626545
05/29/14 04:09 PM
05/29/14 04:09 PM
ME
ME
I forgot to mention that it's a 200 which I believe has larger springs. Can I take out a couple springs in the back of it to get the rear of the van down some?
Re: Best way to lower my 77 dodge van? [Re: 79machocharger] #1626546
05/29/14 06:57 PM
05/29/14 06:57 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
sure, and possibly induce some bad handling problems and reduced load capacity..
I am truckless..
Re: Best way to lower my 77 dodge van? [Re: 340SHORTY] #1626547
05/29/14 08:37 PM
05/29/14 08:37 PM
usa
franks lil red Offline
usa
here is a quick photo chop. just for fun if that's to much I can try again.
Re: Best way to lower my 77 dodge van? [Re: franks lil red] #1626548
05/29/14 11:03 PM
05/29/14 11:03 PM
scratchnfotraction Offline
cut 1.5 coils of front spring. use a set of 2" rear drop shackles for 40 bux from advanced auto parts.
I just used a set of the chebby drop shackles with correct bolt size on my 85 stepside.
Re: Best way to lower my 77 dodge van? [Re: franks lil red] #1626549
05/30/14 02:42 PM
05/30/14 02:42 PM
ME
ME
That's pretty cool. I probably wont go that low. Probably a couple of inches higher then that. The front end is not that bad where it sits but the rear end of the van really sits up way too high right now. I think just getting that down some will help the looks of it a lot.
Re: Best way to lower my 77 dodge van? [Re: 79machocharger] #1626550
05/30/14 10:07 PM
05/30/14 10:07 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I have NOT lowered an earlier B van, so this may not apply.
I did lower the front of my 2002 B2500. Cut just under a full coil off. Rides poorly, so I expect you will also need to change shocks and of course an alignment. The rear requires longer shackles, BUT the shackle goes from the body UP to the end of the spring, and to lower it much will put the spring eye above the floor, requiring cutting a hole then boxing in the area. I didn't do that yet.
I also swapped on late model truck wheels that required some spacers, studs and grinding in front, and some thick spacers in the rear, with low profile 17s.
Re: Best way to lower my 77 dodge van? [Re: 79machocharger] #1626551
06/03/14 12:12 PM
06/03/14 12:12 PM
Appleton WI 54911
Lukester Offline
Lukester  Offline
Appleton WI 54911
nice looking van.......
Re: Best way to lower my 77 dodge van? [Re: Lukester] #1626552
06/03/14 03:17 PM
06/03/14 03:17 PM
ME
ME
Thanks, I'm actually repainting it all this coming winter to look like the one used in the brochures. I've found some chrome slots for it as well as the 5 piece spoiler kit for it. The factory 318 will be coming out of it and a 2003 360 magnum will be going into it that's slightly modified and now carbureted. Also picked up a factory sky light sunroof for it as well.
Re: Best way to lower my 77 dodge van? [Re: 79machocharger] #1626553
07/22/14 12:30 AM
07/22/14 12:30 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
Do your lowers have spring pockets?if not,some heavier vans and trucks did.dont know specifics tho.
