Auto Trans Noise Question.
#1626421
05/29/14 12:32 PM
05/29/14 12:32 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Posted this in the q and a section and apparently nobody knows anything about Dodge automatics, so, I'll give it a go here:
It's a 46re in an '01 Ram that developed a louder-than-usual whine in 1st, 2nd, and 3rd. The pitch changes on gearshifts. 4th gear seems fine, no noticible noise.
Fluid is darker than normal but still has it's reddish color.
Doesn't do it when the truck is cold.
This just started a couple of days ago. At highway speeds everything is fine and the truck pulls great with no slippage.
If I'm not mistaken, this trans is based off the 727 so hopefully you guys have run into this before.
The only thing out of the ordinary is I'm using an electric fan so there would be zero airflow across the trans cooler with the fan left off which is 95% of the time.
Any suggestions?
Mo' Farts
Moderated by "tbagger".
Re: Auto Trans Noise Question.
[Re: Grizzly]
#1626422
05/29/14 12:42 PM
05/29/14 12:42 PM
Guitar Jones
Without hearing it I would say it's the torque converter going south. In O/D the converter is locked up so no noise.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: BulletBob]
#1626424
05/30/14 02:44 AM
05/30/14 02:44 AM
Posts: 6,003 Salem
Grizzly
Salem
Thanks for the replies, Guys. It sounds really similar to a power steering pump. I'll see if I can capture a video with some sound for you. Just hit 200,000 miles with it and I havn't abused or grunted on it. Of course, I've had my Special Friends of a few bad TPS's make life miserable for the old torque converter in the past.
Mo' Farts
[Re: Grizzly]
#1626425
05/30/14 02:02 PM
05/30/14 02:02 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you suspect the converter is the problem, just shut off the OD; the converter will lock up even with the OD disabled.
[Re: John_Kunkel]
#1626426
05/31/14 01:50 AM
05/31/14 01:50 AM
Posts: 6,003 Salem
Grizzly
Salem
I did try that John, and for what I can hear (Flowmaster exhaust drowning everything out ), it goes away. I stopped in at a local Chrysler dealer, talked to their transmission guy and torque converter was the first thing he said too. So, I wonder how long it will last?
Mo' Farts
[Re: BulletBob]
#1626428
05/31/14 04:25 PM
05/31/14 04:25 PM
Guitar Jones
The trash from it will most likely collect in front of the OD unit starving it for fluid thus causing more damage
Don't wait, as Bob said the metal from the converter will trash the entire transmission. I've seen them so bad even the valve body can't be fixed.
[Re: Guitar Jones]
#1626429
06/01/14 02:12 AM
06/01/14 02:12 AM
Posts: 6,003 Salem
Grizzly
Salem
I'll take your Guys' advice. I'm willing to pay more for a brand-new converter from Mopar if it's available. Or, is there something you can recommend? I'm in it for the long haul with this truck and would be reluctant to put any of that aftermarket junk in it.
Mo' Farts
[Re: SANDYinNS Canada]
#1626431
06/05/14 07:31 PM
06/05/14 07:31 PM
Guitar Jones
You can't buy a "new" converter from Mopar. All they sell is remans.
[Re: 727builder]
#1626435
06/07/14 02:32 AM
06/07/14 02:32 AM
Posts: 6,003 Salem
Grizzly
Salem
I've heard that check ball can be a trouble-maker. I'm not real sure on it's purpose, but I thought they put it in there so you don't get the "have to rev 'er up in gear after it's been sitting a few days to get it moving" syndrome. Going without it won't affect the truck in cold weather will it? I'll give it a try, thank-you for the suggestion.
Mo' Farts
[Re: 727builder]
#1626437
06/07/14 05:34 PM
06/07/14 05:34 PM
John_Kunkel
Rio Linda, CA
The so-called converter drainback valve actually prevents the high-mounted cooler in the radiator side tank from draining back through the converter. Nothing can prevent the converter from draining back.
Anecdotal tales of lockup converters lasting hundreds of thousands of miles are the exception rather than the rule. If given the choice of a factory or aftermarket lockup converter I wouldn't choose the factory.
[Re: ChinooK440]
#1626439
06/18/14 07:17 PM
06/18/14 07:17 PM
Posts: 3,934 Nova Scotia Canada B2Y 1E4
SANDYinNS Canada
sorry to hear that you offended a shop if the couldn't answer you on the clutch the either reuse the factory used clutch or god knows what. There are several types of clutches available Kevlar is the best one for most applications although carbon fiber is overkill IMHO.. I'm way too far away to deal with but I have been in the trade for 25+ years and my own shop for 17 in same location my shop
Sandy in Nova Scotia formerly drdodge340 68 coronet wagon, 68 formula s 340 fb barracuda-69 super bee-72 aussie charger-72 aussie vh dodge ute -76 feather duster-76 duster-77 street van - 98 ram 1500 SS/T-99 ram 1500-13 ram red express truck- 2015 hellcat challenger
#1626440
06/20/14 12:42 AM
06/20/14 12:42 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I cant get over the shop wanting to charge you $2700 to R&R and rebuild a 46RE. All I can say is wow. They must be counting on the case and everything being un-usable. I need to move where you are to rebuild transmissions.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
