Re: To undercoat or not to undercoat
[Re: Stewpar]
#1625638
05/27/14 11:31 AM
05/27/14 11:31 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I have done it both ways and prefer less is better. It sounds like you are a bit like me, so I would do what the factory did (w/non undercoated cars) and undercoat the rear wheel wells as well as the front inner fender wells and call it a day!
Agreed....
[Re: Aar1064]
#1625642
05/28/14 09:54 AM
05/28/14 09:54 AM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
What part of TN are you in?
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Stewpar]
#1625649
05/30/14 11:35 AM
05/30/14 11:35 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
It's rare to see a restored car fully undercoated. I usually do it on mine since I drive them. Although I do agree, it can look like your hiding something, but if done right, I don't think it does.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#1625650
05/30/14 11:55 AM
05/30/14 11:55 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
If you paint it, do it like the factory did, not totally painted body color like the top side. I am working on a 71 B-body and it is a factory undercoated car. We did it with dip primer and overspray like the factory. Took pics and then undercoated the undercarriage like it was according to the original pics we took. I like the results. Just be sure and use the correct undercoating and you will never have any problems cleaning it after it dries. If it were my car and I was doing it as close to original as possible no doubt it would be undercoated, especially since it was a FACTORY undercoated car and not done by the dealer.
This
There's always another option as well. Follow the above procedure and stop before adding the final undercoating, or just do the wheel wells like all cars got. You can always add the undercoating later on if you so desire. Don't forget, undercoating cars also got under hood pads. If you decide to leave off the undercoating, also leave off the under hood pad, again, it can always be added later but the clips will usually scratch your paint going in so be sure before adding one.
