Re: need advice on emissions test
[Re: apairof66s]
#162536
12/05/08 11:34 AM
12/05/08 11:34 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks for the reply. They use the probes in the tail pipe and run it on the dyno. How should i lean out the mixture?
Do you suspect the cam is still stock? How wild is it? That's the biggest cause of higher emissions. If it is fairly mild, you may be suprised to pass the test since you only have to pass '68 standards (I'd imagine). My stock 318 passed with no problems in nevada. After I swapped the cam, intake and headers, I couldn't pass it.
You would lean out the mixture on the edelbrock carb by turning the idle mixture screws clockwise, as well as changing the metering rods to a thicker rod.
My best suggestion is to hook the vacuum advance back up, and running it on the test. Get a copy of the readings IF you don't pass..and we can look at those and see what the engine is doing. (too rich, lean, etc).
[Re: apairof66s]
#162540
12/05/08 12:50 PM
12/05/08 12:50 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
When I retard the timing a couple of degrees the idle drops (as to be expected). The vaccum reads 10 in. hc. the more retarded the timing the less vaccum, correct ????
Yes you will have to increase your idle setting to compensate. If your starting at 10 btdc I would probably drop it to 5. Yes, less vacuum. How much vacuum do you have at 10btdc and 'normal' idle? Hopefully at least 15-16? Much less would indicate a higher duration than stock cam (in all probability, could be other things of course)
[Re: apairof66s]
#162548
12/05/08 02:45 PM
12/05/08 02:45 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
Put classic car insurance on it and you don't have to pass emissions anymore!!
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
[Re: dmerc]
#162550
12/05/08 03:31 PM
12/05/08 03:31 PM
Prodart440
Avondale AZ
In AZ it is 67 and newer unless it is on a classic car insurance and NOT a daily driver.
Aaron
[Re: apairof66s]
#162551
12/05/08 04:20 PM
12/05/08 04:20 PM
Pacnorthcuda
I checked the timing before changing anything and it read 16 to 17 degrees btdc. I retarded it to about 12 and turned up the idle a little. It seems to have a rougher idle at this point. The vaccum is reading 9..........
Your vacuum is only 9" ???? At what RPM?
Thats really low for anything expecting to pass emissions. You might try setting the timing a little higher just to get some vacuum back. But again, What is the idle speed?
