need advice on emissions test #162532
12/05/08 10:37 AM
12/05/08 10:37 AM
North Carolina
apairof66s Offline OP
North Carolina
I recently got my 68 Coronet running and now I need to pass emissions here in Arizona.
The motor is a 318,(probably original) with X heads,Offy dual plane intake,Edelbrock 1406 carb,and headers.
The vaccum advance is disconnected at the distributor and all vaccum ports on the carb are plugged.
Except for the new carb this is the setup that the car had when I bought it.
It has a automatic trans.
What I don't know is if the motor has 68 stock internals, ie; pistons, cam etc.
In this county you must pass emissions to register the car.
Any advice would be greatly appreciated........
Re: need advice on emissions test [Re: apairof66s] #162533
12/05/08 10:41 AM
12/05/08 10:41 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If I remember in Vegas was the max idle rpm was 1,200. It'd be best to try and idle it up as close as you can to help clean it up. Also leaning out the mixture some as well. Is it just a sniffer? dyno?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: need advice on emissions test [Re: apairof66s] #162534
12/05/08 11:25 AM
12/05/08 11:25 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Smogging a '68 is asinine! Let's spend that money on illegal immigration.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: need advice on emissions test [Re: GoodysGotaCuda] #162535
12/05/08 11:26 AM
12/05/08 11:26 AM
North Carolina
North Carolina
Thanks for the reply.
They use the probes in the tail pipe and run it on the dyno.
How should i lean out the mixture?
Re: need advice on emissions test [Re: apairof66s] #162536
12/05/08 11:34 AM
12/05/08 11:34 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Do you suspect the cam is still stock? How wild is it? That's the biggest cause of higher emissions. If it is fairly mild, you may be suprised to pass the test since you only have to pass '68 standards (I'd imagine). My stock 318 passed with no problems in nevada. After I swapped the cam, intake and headers, I couldn't pass it.
You would lean out the mixture on the edelbrock carb by turning the idle mixture screws clockwise, as well as changing the metering rods to a thicker rod.
My best suggestion is to hook the vacuum advance back up, and running it on the test. Get a copy of the readings IF you don't pass..and we can look at those and see what the engine is doing. (too rich, lean, etc).
2020 RAM 1500
Re: need advice on emissions test [Re: apairof66s] #162537
12/05/08 11:53 AM
12/05/08 11:53 AM
Kirkland, Washington
Pacnorthcuda Offline
1)Pray you have something close to a stock cam.
2)As Goody stated, raise your idle to something in the 1000-1100 range (you may want to check on max allowable first, I think states vary)
3) Retard your timing! You want something in the 2-6 BTDC at idle--this can help big time
4) Lean the carb a bit but be careful--too much and you'll increase CO emmisions
5) Clean air filter--or NO air filter
6) Fresh oil change (it helps a bit)
7) An alcohol fuel mixture (at least 10%, you can increase it with gas line antifreeze in a nearly empty tank)
8) Make sure engine is warm, coolant temp should be at least 190
I agree smogging a 68 is insane
Re: need advice on emissions test [Re: Pacnorthcuda] #162538
12/05/08 11:59 AM
12/05/08 11:59 AM
North Carolina
North Carolina
Here's the max allowable hydrocarbons (hc) in ppm : 260 (loaded)
Carbon monoxide (co) in % : 3.89
Re: need advice on emissions test [Re: apairof66s] #162539
12/05/08 12:26 PM
12/05/08 12:26 PM
North Carolina
North Carolina
When I retard the timing a couple of degrees the idle drops (as to be expected).
The vaccum reads 10 in. hc.
the more retarded the timing the less vaccum, correct ????
Re: need advice on emissions test [Re: apairof66s] #162540
12/05/08 12:50 PM
12/05/08 12:50 PM
Yes you will have to increase your idle setting to compensate.
If your starting at 10 btdc I would probably drop it to 5.
Yes, less vacuum. How much vacuum do you have at 10btdc and 'normal' idle? Hopefully at least 15-16? Much less would indicate a higher duration than stock cam (in all probability, could be other things of course)
Re: need advice on emissions test [Re: apairof66s] #162541
12/05/08 01:05 PM
12/05/08 01:05 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
run the tank down to about 1/4 and add 1 to 2 gal of methanol, if you add to much it run like crap, if that happens add about another gal of gas..
and it will pass the sniffer test.. then go fill the tank up asap.
Re: need advice on emissions test [Re: Pacnorthcuda] #162542
12/05/08 01:07 PM
12/05/08 01:07 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
An msd box will help a buch with the lower rpm portion of the test if you have any sort of cam in it.
The air screws on the carburetor make a big difference. Finding the sweet spot can be tricky if you have an engine that is borderline on passing. You can always take it to a service station and have them set it up for you with their equipment and then take it back and get it tested.
If all else fails buy some catalytic convertors without the air tube and splice them in as far forward as you can.
Testing old cars is a money grab if you ask me. Sure they pollute more than new ones, but the amount of time they spend on the road is very small. Most people drive them a few times a month in the summer to go to car shows and thats about it.
Re: need advice on emissions test [Re: Pacnorthcuda] #162543
12/05/08 01:09 PM
12/05/08 01:09 PM
North Carolina
North Carolina
I checked the timing before changing anything and it read 16 to 17 degrees btdc. I retarded it to about 12 and turned up the idle a little. It seems to have a rougher idle at this point.
The vaccum is reading 9..........
Re: need advice on emissions test [Re: apairof66s] #162544
12/05/08 01:17 PM
12/05/08 01:17 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
If you have not had it tested yet do that first, but get the engine tuned up and running smooth. Get some base numbers to start with first before you start chasing a problem that may or may not exist yet.
https://board.moparts.org/ubbthreads/show...e=1#Post4446839
Re: need advice on emissions test [Re: Neil] #162545
12/05/08 01:20 PM
12/05/08 01:20 PM
North Carolina
North Carolina
Thanks for all the replies.
I was hoping to pass on the first test !
Are my settings close enough to go try it ?
Re: need advice on emissions test [Re: apairof66s] #162546
12/05/08 01:23 PM
12/05/08 01:23 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I would set the timing to stock and make sure it has new plugs, plug wires, pvc, oil, air filter etc. and then test it.
Re: need advice on emissions test [Re: Neil] #162547
12/05/08 01:26 PM
12/05/08 01:26 PM
North Carolina
North Carolina
Thanks.
I'll post the results later today........
Re: need advice on emissions test [Re: apairof66s] #162548
12/05/08 02:45 PM
12/05/08 02:45 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
Put classic car insurance on it and you don't have to pass emissions anymore!!
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: need advice on emissions test [Re: apairof66s] #162549
12/05/08 02:59 PM
12/05/08 02:59 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I thought only cars after 74 had to be sniffed. That's the way it is in NM.
Re: need advice on emissions test [Re: dmerc] #162550
12/05/08 03:31 PM
12/05/08 03:31 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
In AZ it is 67 and newer unless it is on a classic car insurance and NOT a daily driver.
Aaron
68 Coronet 440
Re: need advice on emissions test [Re: apairof66s] #162551
12/05/08 04:20 PM
12/05/08 04:20 PM
Your vacuum is only 9" ???? At what RPM?
Thats really low for anything expecting to pass emissions. You might try setting the timing a little higher just to get some vacuum back. But again, What is the idle speed?
