Fuel cell vent(s)? #1624799
05/25/14 04:55 PM
05/25/14 04:55 PM
Wheels up, MO
N
nhramark Offline OP
nhramark  Offline OP
N
Wheels up, MO
I am returning my Duster to some very limited street duty - slicks, wheelie bars, alcohol, (fuel not cocktails ) etc. I'm having a custom aluminum 22 gallon fuel cell built due to the horrendous fuel mileage expected.
As to venting the cell, I've considered two -6 vents, one -6 vent, or one -8 vent. Anybody have any experience with this?
The rollover valves are fairly expensive once you include the fittings and hoses. I don't mind spending for what is needed, but I hate wasting money....
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: Fuel cell vent(s)? [Re: nhramark] #1624800
05/25/14 04:59 PM
05/25/14 04:59 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The amount of fuel leaving the cell is what you need to consider. I have imploded a plastic cell or two without the proper venting. If you have an AN8 leaving, then an AN8 vent should be used. If you have two AN8's leaving, then upsizing it, will be need to keep from creating a vacuum. My A1000 did a number on a plastic fuel cell of mine.
Re: Fuel cell vent(s)? [Re: Dragula] #1624801
05/25/14 07:05 PM
05/25/14 07:05 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I run a -8 with a roll over bulkhead fitting.
http://www.summitracing.com/parts/sum-g3114/overview/
Some of them can be plumbed in line however they seem to be more expensive.
Re: Fuel cell vent(s)? [Re: nhramark] #1624802
05/25/14 10:22 PM
05/25/14 10:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The filler cap is also vented so a single -8 is plenty
Re: Fuel cell vent(s)? [Re: MR_P_BODY] #1624803
05/26/14 12:08 PM
05/26/14 12:08 PM
Wheels up, MO
N
nhramark Offline OP
nhramark  Offline OP
N
Wheels up, MO
uh-oh, I hadn't thought about the cap. So it will be venting alcohol fumes into my trunk... where my battery sits? That's going to create new problems.
Re: Fuel cell vent(s)? [Re: nhramark] #1624804
05/26/14 12:40 PM
05/26/14 12:40 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The cap on my cell is a non-vented aircraft style deal. It has a safety blow off but is not normally vented.
Re: Fuel cell vent(s)? [Re: nhramark] #1624805
05/26/14 12:41 PM
05/26/14 12:41 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Pro-Werks makes screw on replacement caps that are not vented. Use that and vent sizes equal to what you have feeding the pump and you will be good.
Re: Fuel cell vent(s)? [Re: nhramark] #1624806
05/26/14 03:46 PM
05/26/14 03:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
They have a pressure and vac valve in them... if you
pump MOST of the pressure through the vent line it
wont dump thru the cap.. I forget the vac/pressure
settings are on it but its like 29-35" of water for
the pressure side and 10" of water vac... so if you
dump the pressure off on the line you wont have to
worry
EDIT
if it has a hole in the center thats in the tank it
has the valve
Re: Fuel cell vent(s)? [Re: MR_P_BODY] #1624807
05/26/14 09:23 PM
05/26/14 09:23 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
