Re: New Best & Kicked Out
[Re: 6bblFLASH]
#1624308
05/24/14 05:58 PM
05/24/14 05:58 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yeah, drive ratio would get the boost in earlier in the RPM range its at now. I don`t know if I could hook-up more boost down low without making the chassis more drag freindly. have MT ET DragRadials 295/75`s on there now. But also need to explore jetting/timing/shift points etc.... Wouldn`t be suprise to see a couple 10ths left in it. Quaker City actually goes uphill and traction is 50/50 most days. All else equal Norwalk or Columbus would be at least a 10th and a couple mph as is.....
Being that your all stock (shocks included) its real hard to tune in the chassis
[Re: 6bblFLASH]
#1624311
05/24/14 11:54 PM
05/24/14 11:54 PM
Posts: 949 Alliance, Ohio
Valiant_Showoff
Alliance, Ohio
Cant you change your pulley ratio to get boost sooner and more of it... whats that little blower worth for max pressure
Ratio is 2.13 to 1. I`ve seen 2.42 to 1. Read some SBF/SBC stuff on YellowBullet that got 10/13lbs. out of them. But they spum the blower 16,000 rpm with Alcohol/E-85 set-ups.
I was thinking if I could get a converter made that was soft enough to minimize the drop on the shifts yet act stockish on the highway it could pickup quit a bit. Choose the 3.33 gear for street manners,I think 3.73 would really wake her up. IF i could get traction. Chassis is STOCK..shocks/sway-bar/battery in front/heavy everythingetc...... Really starts to pull at the 1,000 ft mark,Guessing if I could get it to use 5,200/5,500 shifts it would really fly. Also could be its too rich/not enough timing and its that late in a pass till it gets into its sweet-spot.
Its only been 14-hours and I`m already thinking about a roll-bar and gears and converters and cams and divorce,,,cause the wife will kill me if I ruin "her" car LOL
Old habits die hard....
Don't worry about the divorce. You don't have much she would want anyway. Put a cage in it and go bang on it!
Seriously though, very cool. About time something worked right on that car.
