9 1/4 POSI JUNK I 5000 MILES #1624198
05/23/14 07:19 PM
05/23/14 07:19 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
MY 9 1/4 POSI IS JUNK ALONG WITH 1 AXEL.
LOOKS LIKE IT HAS 150,000 MILES ON IT.
THE CROSS PIN IS WORN BAD ALONG WITH THE SPIDER GEARS
SIDE GEARS ARE WARN ONLY IN THE MIDDLE
SIDE CONES ARE BAD
RING AND PINION LOOK OK
THE DIFF AND PINION BEARINGS LOOK OK
HAD THE HOUSING AND AXELS NARROWED 3 YEARS AGO
ONLY 5000 MILES ON REAR ASSEMBLY
LET ME KNOW WHAT YOU THINK BEFORE I BUY ANOTHER ONE
Re: 3.73 FOR 9 1/4 [Re: BUBBAZ572] #1624199
05/23/14 10:45 PM
05/23/14 10:45 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
Been a while since I have looked at gears for one but I believe your only choices close to 3.73 are 3.92 or 3.55
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624200
05/29/14 07:14 PM
05/29/14 07:14 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
NEED HELP
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624201
05/29/14 07:31 PM
05/29/14 07:31 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
What are you asking while yelling about it.
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624202
05/30/14 09:54 AM
05/30/14 09:54 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
LET ME KNOW WHAT YOU THINK BEFORE....
I'll tell you what I think...
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: Commando1] #1624203
05/30/14 10:32 AM
05/30/14 10:32 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Me thinks you shouldn't have put money in a 140k+ rearend or even a 9 1/4 for that matter, not that it's a bad rear I just wouldn't have put any money into it. Buy a truck 60 with a locker and good gears and modify it for your needs. Stronger and better supported by the aftermarket and in the end a much more desireable rear.
Careful, your character's showing!
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: mopar346] #1624204
05/30/14 10:57 AM
05/30/14 10:57 AM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
IT WAS FREE AND HAS DISC BRAKES
GREAT UPGRADE FROM 45 YEAR OLD DRUMS
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: stumpy] #1624205
05/30/14 11:18 AM
05/30/14 11:18 AM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
THANKS FOR THE GREAT ADVISE.
I HAVE ADVISE FOR YOU!
TRY 1 SIZE BIGGER ON YOUR UNDERWARE
OR HAVE YOUR DOCTOR REMOVE THAT BUG
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624206
05/30/14 11:26 AM
05/30/14 11:26 AM
Cincinnati, Ohio
Challenger 1 Online tonguue
Challenger 1  Online Tonguue
Cincinnati, Ohio
SIDE CONES ARE BAD
I think you should turn off the caps, it makes your post harder to read.
You asked what I think.
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624207
05/30/14 11:30 AM
05/30/14 11:30 AM
mopar346 Offline
mopar346  Offline
Maybe you should quote who you intended to insult so they know to be offended.
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624208
05/30/14 01:57 PM
05/30/14 01:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Why did you shove a GM posi unit in your Chrysler differential?
Why did you have to YELL at everyone?
The kind of damage you described comes from either overheating (low fluid or heavy load) or improper assembly.
- Stu Harmon
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: mopar346] #1624209
05/30/14 06:01 PM
05/30/14 06:01 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
A fresh Spicer/ Dana trac loc unit will set you back 3-500 plus the labor.
Not a great performance part, but they have been making them for 30 or so years..so not terrible.
The upgrade to Dana60 will get you the same design trac loc unit in a larger format.
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624210
05/30/14 06:40 PM
05/30/14 06:40 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I've found that free sometimes costs more $$$.
9.25 rears are known to have pinion pre-load (crush sleeve tension lessens) and cross shaft wear problems.
Put the discs on a Dana 60.
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: BUBBAZ572] #1624211
05/30/14 07:44 PM
05/30/14 07:44 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
109 posts and already got himself a title!
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: B5 Bee] #1624212
05/30/14 07:52 PM
05/30/14 07:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I got to the "posi" part and gave up. If he can put a GM posi in a Chrysler rearend he doesnt need my assistance.
I am truckless..
Re: 9 1/4 POSI JUNK I 5000 MILES [Re: 340SHORTY] #1624213
05/30/14 07:55 PM
05/30/14 07:55 PM
Commando1 Offline
Commando1  Offline
The joke's on MRCAPS.
The disc brake parts are unobtanium.
The 74-75 Imperial owners are swapping them out for the drum setup.
