9 1/4 POSI JUNK I 5000 MILES
#1624198
05/23/14 07:19 PM
05/23/14 07:19 PM
Posts: 109 OHIO
BUBBAZ572
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
MY 9 1/4 POSI IS JUNK ALONG WITH 1 AXEL. LOOKS LIKE IT HAS 150,000 MILES ON IT. THE CROSS PIN IS WORN BAD ALONG WITH THE SPIDER GEARS SIDE GEARS ARE WARN ONLY IN THE MIDDLE SIDE CONES ARE BAD RING AND PINION LOOK OK THE DIFF AND PINION BEARINGS LOOK OK HAD THE HOUSING AND AXELS NARROWED 3 YEARS AGO ONLY 5000 MILES ON REAR ASSEMBLY LET ME KNOW WHAT YOU THINK BEFORE I BUY ANOTHER ONE
Re: 9 1/4 POSI JUNK I 5000 MILES
[Re: Commando1]
#1624203
05/30/14 10:32 AM
05/30/14 10:32 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Me thinks you shouldn't have put money in a 140k+ rearend or even a 9 1/4 for that matter, not that it's a bad rear I just wouldn't have put any money into it. Buy a truck 60 with a locker and good gears and modify it for your needs. Stronger and better supported by the aftermarket and in the end a much more desireable rear.
Careful, your character's showing!
[Re: stumpy]
#1624205
05/30/14 11:18 AM
05/30/14 11:18 AM
Posts: 109 OHIO
BUBBAZ572
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
THANKS FOR THE GREAT ADVISE. I HAVE ADVISE FOR YOU! TRY 1 SIZE BIGGER ON YOUR UNDERWARE OR HAVE YOUR DOCTOR REMOVE THAT BUG
[Re: BUBBAZ572]
#1624206
05/30/14 11:26 AM
05/30/14 11:26 AM
Challenger 1
Cincinnati, Ohio
I think you should turn off the caps, it makes your post harder to read.
You asked what I think.
[Re: BUBBAZ572]
#1624208
05/30/14 01:57 PM
05/30/14 01:57 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Why did you shove a GM posi unit in your Chrysler differential?
Why did you have to YELL at everyone?
The kind of damage you described comes from either overheating (low fluid or heavy load) or improper assembly.
[Re: mopar346]
#1624209
05/30/14 06:01 PM
05/30/14 06:01 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
A fresh Spicer/ Dana trac loc unit will set you back 3-500 plus the labor. Not a great performance part, but they have been making them for 30 or so years..so not terrible. The upgrade to Dana60 will get you the same design trac loc unit in a larger format.
[Re: BUBBAZ572]
#1624210
05/30/14 06:40 PM
05/30/14 06:40 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
IT WAS FREE AND HAS DISC BRAKES GREAT UPGRADE FROM 45 YEAR OLD DRUMS
I've found that free sometimes costs more $$$.
9.25 rears are known to have pinion pre-load (crush sleeve tension lessens) and cross shaft wear problems.
Put the discs on a Dana 60.
[Re: 340SHORTY]
#1624213
05/30/14 07:55 PM
05/30/14 07:55 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
The joke's on MRCAPS. ....................... The disc brake parts are unobtanium. The 74-75 Imperial owners are swapping them out for the drum setup.
