Used Holley #1623930
05/23/14 12:07 AM
05/23/14 12:07 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I am going to the NMCA meet tomorrow in STL. A friend of a friend will be there at the swap meet with a bunch of carbs. I am looking for a manual choke, vacuum secondary 750 Holley and he thinks that he has one. I am not really pressed to find one now, but I would like something that I could rebuild this winter to replace the Eddy 1407 that is on my 340 now.
I was wondering what to look, or lookout, for. Stripped threads, broken or cracked baseplate ears, missing linkage pieces, etc. Will the list number matter as it will be need to be rejetted?
Also, what do you think that I should pay?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Used Holley [Re: cdstl] #1623931
05/23/14 01:14 AM
05/23/14 01:14 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
My is a buy anew one and alleviate the "SWAP"MEAT" " deal.
Yes that was a double quote and not misspelled. If you're a carb guru you MAY be able to save a few bucks. If not you'll probably wind up with more headaches that the price difference was worth Again MY
Re: Used Holley [Re: TJP] #1623932
05/23/14 01:56 AM
05/23/14 01:56 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree with this. If you know carbs well and can build them yourself then yea if it has problems you can fix it. But if you dont know carbs you could end up with a headache thats not worth the savings. Best bet would be buy new and dont take a chance of getting a bunch of headaches. Ron
Re: Used Holley [Re: TJP] #1623933
05/23/14 02:02 AM
05/23/14 02:02 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
It's the things you can't see that plague used carbs, warped bodies and such come to mind. Unless you can see it run and IDLE on an engine before you purchase it I would never buy a used carb.
Re: Used Holley [Re: loaderpro] #1623934
05/23/14 04:42 AM
05/23/14 04:42 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
This.
Many used carbs are for sale because someone has been hacking on them when they have no clue what they are doing.
Re: Used Holley [Re: cdstl] #1623935
05/23/14 08:59 AM
05/23/14 08:59 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
OK then, questions answered. I will wait.
Re: Used Holley [Re: cdstl] #1623936
05/23/14 09:53 AM
05/23/14 09:53 AM
Minnesota
peabodyracing Offline
Minnesota
Probably just dumb luck on my part but I've done fine buying used Holleys and in fact pick them up any time I see one priced right. As long as the shafts aren't loose in the body, or are frozen in place or there are obvious signs of distress I've generally not run into anything I couldn't sort out. I'm no carburetor whiz either.
The 3310's like I suspect you're thinking of are my favorite. If you reconsider looking for one, I prefer the earlier ones with the metering block on both ends of the carb. The newer ones are a bit prone to problems with the metering plate on the secondary side, plus it's easier to switch up jets working with the metering block.
I do have one on the shelf I bought really cheap, that doesn't seem to want to cooperate, but I've not spent a lot of time on it yet. That's really the only problem one I've run into.
Lead, follow or get the hell out of the way
Re: Used Holley [Re: peabodyracing] #1623937
05/23/14 10:12 AM
05/23/14 10:12 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lol buying used carbs is a crapshoot....look at the Moparts.com classifids....there are more used carbs for sale than anything else...the old 3310 series with vacuum secondary was the go to carb in the 70s,80s...worked good with hyd cam,headers,dual plane intake,dual point dist or electronic...buying them used now...you can spend countless hours...rebuilding them, taking them apart,trying to fix warped baseplates, wallowed out shafts, casting imperfections etc. for the time and money involved...it aint worth it unless your topping something you want to unload quick.lots of new ideas&technology have surfaced in carbs...Demons,Quick Fuel, etc. go that route and save the headache..spend more now to save time later...
Re: Used Holley [Re: Joesixpack] #1623938
05/23/14 10:34 AM
05/23/14 10:34 AM
Plymouth, MI
HotRod20 Offline
HotRod20  Offline
Plymouth, MI
I agree with everyone who says "forget the used carb at swap meets"...I use the same approach for swap meet torque convertors. Buy a new carb.
HR 20
Re: Used Holley [Re: HotRod20] #1623939
05/23/14 11:05 AM
05/23/14 11:05 AM
I'd always thought a person might do OK rebuilding a used one if the price is right & the condition/shaft play is acceptable which that is external conditions but I've heard for years regarding issues with used ones & most everyone on this thread feels the same way. If the price is right take a chance & if a new one is in teh budget then what Joe said get one of the Holley clones that have adjustable systems so when you get your Innovate LM1 (or similar) AF meter you can dial in all of the systems dead on. reportedly is a night and day difference once you get it perfect
Re: Used Holley [Re: cdstl] #1623940
05/23/14 11:09 AM
05/23/14 11:09 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you decide to go ahead and try a used carb, in my opinion the most important thing to look for is if it has been apart. I have bought a lot of swap meet carbs for myself and for buddies. Only a very few have been crap. Most have worked out fine. The only ones I have had real troubles with are the ones that have been apart.
If you decide to go new, the Street Demon just got a very good review in the carb shoot out in the new Mopar Muscle mag. It is definitely the go-to carb today.
Master, again and still
Re: Used Holley [Re: DaveRS23] #1623941
05/23/14 01:17 PM
05/23/14 01:17 PM
Park Forest, IL
Park Forest, IL
The problem with used Holleys is that people like to mix and match parts from different series carbs thinking it is going to make huge performance differences. Unfortunately, not all the parts play well together and you end up with a carb that is almost impossible to make work again unless you are very familiar with them.
Sometimes it is as simple as a float bowl gasket that means the difference between a good carb and a fire starter.
Re: Used Holley [Re: slantzilla] #1623942
05/23/14 05:56 PM
05/23/14 05:56 PM
P
Paul_Fancsali Offline
P
The Holley is one of the easiest to fix when messed up The worst of the bunch is a the edel crap you have on that 340 now a good Holley will give you a .2+ in qtr if not more
