Used Holley
#1623930
05/23/14 12:07 AM
05/23/14 12:07 AM
Posts: 1,487 STL
cdstl
STL
I am going to the NMCA meet tomorrow in STL. A friend of a friend will be there at the swap meet with a bunch of carbs. I am looking for a manual choke, vacuum secondary 750 Holley and he thinks that he has one. I am not really pressed to find one now, but I would like something that I could rebuild this winter to replace the Eddy 1407 that is on my 340 now.
I was wondering what to look, or lookout, for. Stripped threads, broken or cracked baseplate ears, missing linkage pieces, etc. Will the list number matter as it will be need to be rejetted?
Also, what do you think that I should pay?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Used Holley
[Re: TJP]
#1623932
05/23/14 01:56 AM
05/23/14 01:56 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Re: Used Holley
[Re: cdstl]
#1623935
05/23/14 08:59 AM
05/23/14 08:59 AM
Posts: 1,487 STL
cdstl
STL
OK then, questions answered. I will wait.
Re: Used Holley
[Re: cdstl]
#1623936
05/23/14 09:53 AM
05/23/14 09:53 AM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Probably just dumb luck on my part but I've done fine buying used Holleys and in fact pick them up any time I see one priced right. As long as the shafts aren't loose in the body, or are frozen in place or there are obvious signs of distress I've generally not run into anything I couldn't sort out. I'm no carburetor whiz either.
The 3310's like I suspect you're thinking of are my favorite. If you reconsider looking for one, I prefer the earlier ones with the metering block on both ends of the carb. The newer ones are a bit prone to problems with the metering plate on the secondary side, plus it's easier to switch up jets working with the metering block.
I do have one on the shelf I bought really cheap, that doesn't seem to want to cooperate, but I've not spent a lot of time on it yet. That's really the only problem one I've run into.
Lead, follow or get the hell out of the way
Re: Used Holley
[Re: peabodyracing]
#1623937
05/23/14 10:12 AM
05/23/14 10:12 AM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
lol buying used carbs is a crapshoot....look at the Moparts.com classifids....there are more used carbs for sale than anything else...the old 3310 series with vacuum secondary was the go to carb in the 70s,80s...worked good with hyd cam,headers,dual plane intake,dual point dist or electronic...buying them used now...you can spend countless hours...rebuilding them, taking them apart,trying to fix warped baseplates, wallowed out shafts, casting imperfections etc. for the time and money involved...it aint worth it unless your topping something you want to unload quick.lots of new ideas&technology have surfaced in carbs...Demons,Quick Fuel, etc. go that route and save the headache..spend more now to save time later...
Re: Used Holley
[Re: HotRod20]
#1623939
05/23/14 11:05 AM
05/23/14 11:05 AM
RapidRobert
I'd always thought a person might do OK rebuilding a used one if the price is right & the condition/shaft play is acceptable which that is external conditions but I've heard for years regarding issues with used ones & most everyone on this thread feels the same way. If the price is right take a chance & if a new one is in teh budget then what Joe said get one of the Holley clones that have adjustable systems so when you get your Innovate LM1 (or similar) AF meter you can dial in all of the systems dead on. reportedly is a night and day difference once you get it perfect
Re: Used Holley
[Re: cdstl]
#1623940
05/23/14 11:09 AM
05/23/14 11:09 AM
Posts: 12,144 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you decide to go ahead and try a used carb, in my opinion the most important thing to look for is if it has been apart. I have bought a lot of swap meet carbs for myself and for buddies. Only a very few have been crap. Most have worked out fine. The only ones I have had real troubles with are the ones that have been apart. If you decide to go new, the Street Demon just got a very good review in the carb shoot out in the new Mopar Muscle mag. It is definitely the go-to carb today.
Master, again and still
Re: Used Holley
[Re: DaveRS23]
#1623941
05/23/14 01:17 PM
05/23/14 01:17 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
The problem with used Holleys is that people like to mix and match parts from different series carbs thinking it is going to make huge performance differences. Unfortunately, not all the parts play well together and you end up with a carb that is almost impossible to make work again unless you are very familiar with them. Sometimes it is as simple as a float bowl gasket that means the difference between a good carb and a fire starter.
