Re: 1994 Ram 2500 brake lines
[Re: nd65]
#1622953
05/21/14 12:09 PM
05/21/14 12:09 PM
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: nd65]
#1622955
05/21/14 02:36 PM
05/21/14 02:36 PM
Guitar Jones
That may depend. Typically the master cylinder fittings are not the standard size you get on a piece of line. In that case you will need to cut the old lines to get the fittings off and then cut the new line, slide the new fittings off and the old fittings on then double flare the ends of the new lines. Double flaring tools aren't too expensive and you can practice on some old lines to get the hang of it but it's really easy to do.
[Re: Guitar Jones]
#1622956
05/21/14 02:46 PM
05/21/14 02:46 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
94 should still be double flare.I cant remember when they went to the bubble flares.Adapters are avaliable to go to standard lines though.Rocky
Chrysler Firepower
[Re: therocks]
#1622958
05/21/14 04:48 PM
05/21/14 04:48 PM
Guitar Jones
My 96 was double flare, but either way it's just a tool and a little practice.
[Re: nd65]
#1622961
05/24/14 03:41 PM
05/24/14 03:41 PM
Guitar Jones
The copper line is interesting. I had a buddy give new steel for free last night.
Is there anything out of the ordinary to bleed the brakes on this truck? There are, what I am guessing, a couple of ABS moudules plumbed near the MC.
There shouldn't be. Just follow the normal procedure, bleed master first, then start at the right rear, left rear, right front then left front.
