I have a 70 dart swinger 2dr hardtop. I pulled the /6 and A903 for a small block and 4 speed. I have all the parts thanks to brewers, passon and ebay, but I am trying to weld in the "z bar support bracket" or "torque bar support bracket" or "frame side ball stud support brace" or whatever you want to call it. It's the trapezoidal shaped bracket that reinforces the sheet metal where the frame side ball stud goes. I have seen many names for it and only 3 pictures after hours of searching. What is the correct orientation of the little trapezoidal bracket? Pictures would be greatly appreciated especially if its on a stock 4 speed car. Thanks. Jared
