Page 3 of 4 1 2 3 4
Re: 9" Vs. Dana 60 [Re: astjp2] #1621975
05/20/14 02:42 AM
05/20/14 02:42 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Why dick around with either and run the 70, its a 10.5" ring gear and has the same outer dimensions as a 60. I found one that has 1/2" thick 3.5" diameter tubes that weighed 58# when cut down to size. The 9" pinion is smaller than a dana 44, it only has a 3rd bearing to reduce flex. Nines are just puny compared to a real axle..Tim
Yep, a 9" Ford rear is a POS. That's why it is under 99% of the FAST race cars on the planet
Leon, you can brag about never bending your Dana housing all you want. But if you put a drag radial on that car you will bend it like a pretzel. And it has NOTHING to do with the stronger center part of the housing, it has to do with the UNBRACED tubes. What, you think the mild steel YOUR tubes are made of is magic compared to other types of mild steel
Mopar guys ALWAYS get their freaking panties in a wad if somebody disses the MIGHTY Dana.........which is a company by the way, that is NOT and NEVER was a part of Chrysler.
Again it is all about the intended application. as to which diff you need. Me personally, I don't care if it came from a Mopar, a Chevy, a Ford, a Nash or a damn VW, I just want parts that WORK.
Now again, does EVERY car on the planet need a Ford, or even a DANA rear..........the answer is NO. But for the type cars I personally work with, the answer is YES on the Ford because it is the ONLY one that WORKS.
The stuff people say before they think, just simply amazes me.
Monte
Re: 9" Vs. Dana 60 [Re: Monte_Smith] #1621976
05/20/14 10:58 AM
05/20/14 10:58 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
BTW Monty, the guys got the problem with the Dominator EFI figured out. Thanks
Re: 9" Vs. Dana 60 [Re: justinp61] #1621977
05/20/14 11:15 AM
05/20/14 11:15 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I am running a 8 3/4 and has been good for about 100 passes, Not a real fast car but its heavy and on drag radials. This stroked big block seems to make some pretty good torque down low. I have a truck Dana sitting in my garage but after going back and forth on rear ends I think I will end up with a 9" if this old 8 3/4 decides to go. There is more gear choices for the 9" and just a lot more aftermarket parts available. The other thing is that 60 is a heavy chunk of steel. Who on here doesnt want to save some weight?
67' charger 499 RB 10.57 at 127
Re: 9" Vs. Dana 60 [Re: justinp61] #1621978
05/20/14 11:25 AM
05/20/14 11:25 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Hopefully mine lives a little longer. It's running on borrowed time going 1.31 60 fts on a dead hooking drag radial at 3200 lbs.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 9" Vs. Dana 60 [Re: Jeremiah] #1621979
05/20/14 12:11 PM
05/20/14 12:11 PM
an8sec70cuda Offline
I have a Moser Dana 60 under my hemicuda. Put it in there in 2003 after grenading the 8.75 running mid 10s at 3700 lbs. The car ran mid 9s starting in 2006 and now it's a little faster...would like to see 8s soon.
I've had the rear cover off once...last fall. Just to change the gear oil b/c I realized it had been 10 years.
My car is over 3800 lbs, drag radials, leaf springs, footbraking, etc.
Back in '03 I think I paid about $1800 for the Moser 60. 35 spline axles, spool, 4.10 gear.
The dana gets the nod for my cars for cost versus strength. I built a dana 60 for my dad's '69 road runner. Less than a grand in the whole thing...35 spline axles, powerlock diff, 1350 yoke, etc. Built it from a junkyard truck rear.
If I was starting from scratch and building a FAST car, I'd go w/ a 9". Less weight, VERY strong, and any gear ratio imaginable is available. I would start w/ an aftermarket fabbed housing and big bolt through aluminum case. It wouldn't be cheap, but you'd have one heck of a rear.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 9" Vs. Dana 60 [Re: Monte_Smith] #1621980
05/20/14 01:09 PM
05/20/14 01:09 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I don't have a good mental picture of the failure points in a 60.
Can someone explain why the tubes can't be braced?
Boffin Emeritus
Re: 9" Vs. Dana 60 [Re: Monte_Smith] #1621981
05/20/14 02:57 PM
05/20/14 02:57 PM
dogdays Offline
dogdays  Offline
I'd guess it's because a back brace would get in the way of changing gears.....
Nothing says one couldn't front-brace it, though.
R.
Re: 9" Vs. Dana 60 [Re: dogdays] #1621982
05/20/14 03:01 PM
05/20/14 03:01 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
sense we are talking about rearends. a guy i work with is big into dirt track cars and was trying to talk me into putting a full floating 9 inch under my dart after i told him i blew my 8-3/4. so seeing how i have never messed with one can you even run a full floater in a race car or they just for circle track cars etc? thanks mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: 9" Vs. Dana 60 [Re: mopar65] #1621983
05/20/14 04:03 PM
05/20/14 04:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
A guy that races a Colt at one of the near by drag strips runs a 9" floater. I asked why several years ago and he told me if he broke an axle he didn't want to lose a tire and tear the car up.
Re: 9" Vs. Dana 60 [Re: justinp61] #1621984
05/20/14 06:57 PM
05/20/14 06:57 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you wont loose a tire with a regular 9" they are bolted to the flange
Re: 9" Vs. Dana 60 [Re: Quicktree] #1621985
05/20/14 07:13 PM
05/20/14 07:13 PM
dogdays Offline
dogdays  Offline
Full floating means the hub is supported by the axle housing. The axle shaft only transmits torque from the differential to the hub.
IMHO, there's no reason not to run a full floating rear end on the street other than cost.
R.
Re: 9" Vs. Dana 60 [Re: Quicktree] #1621986
05/21/14 01:16 AM
05/21/14 01:16 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Tell that to my buddy who broke an axle at the bearing on his Omni/Charger and destroyed the rear quarter.
Re: 9" Vs. Dana 60 [Re: justinp61] #1621987
05/21/14 02:50 AM
05/21/14 02:50 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Every commercial truck on the road is floater axle; it's the better way to do it. S/F.....Ken M
Re: 9" Vs. Dana 60 [Re: justinp61] #1621988
05/21/14 05:32 AM
05/21/14 05:32 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Exactly, I've personally seen multiple 9"s break axles outside the bearing. And another thing, why is it at every drag meeting, when you walk around the pits sooner or later you will see it, laying on the grass a 9" pinion still attatched to the drive shaft?????
Re: 9" Vs. Dana 60 [Re: Mcode69] #1621989
05/21/14 07:10 AM
05/21/14 07:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
in all my years of racing I have never seen one break on the outside.
Re: 9" Vs. Dana 60 [Re: Mcode69] #1621990
05/21/14 07:11 AM
05/21/14 07:11 AM
Q
Quicktree Offline
Quicktree  Offline
Q
probably stock parts....
Re: 9" Vs. Dana 60 [Re: Quicktree] #1621991
05/21/14 08:29 AM
05/21/14 08:29 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
There's the deal right there. A stock Dana will live a lot of places a stock 9" won't. Once everything is fortified with high end center sections and fabbed housings it's a different story.
Doug
Re: 9" Vs. Dana 60 [Re: dvw] #1621992
05/21/14 08:44 AM
05/21/14 08:44 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Doug
I don't know how many times we have to say that...
Re: 9" Vs. Dana 60 [Re: dvw] #1621993
05/21/14 04:42 PM
05/21/14 04:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Doug
In stock form the 9" is no better than a 8 3/4 IMO. I broke two of them in an anemic 79 Ford F-150, no it didn't have giant tires either. I've always said that if the 9" as it came from the factory was the greatest Ford wouldn't have used a Dana in their 3/4 and 1 ton trucks and vans. With all the aftermarket support it has it's a great rear. Application, application, application .
BTW Quicktree, the axle that broke on the Omni/Charger was either a Moser or Strange, I don't remember which now.
Re: 9" Vs. Dana 60 [Re: justinp61] #1621994
05/21/14 05:09 PM
05/21/14 05:09 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
There was NO mention of stock part survivability for either rear in the OP's question, so why is it even in the conversation?
I have a 9" in my Road Runner. I cut and backbraced a junk yard housing, then put together a new center section using a new Strange iron center, Detroit Locker, etc... all good parts. Most new and some barely used, I have about a Grand in the center section. Im also using new Moser Axles. All in total, I have about $1800 into it.
I went with the 9" because I like the way the look, all backbraced etc.... also to have ease of gear change........one center for track, one for street.
Page 3 of 4 1 2 3 4
