BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) #1620807
05/16/14 09:22 PM
05/16/14 09:22 PM
Tampa
DusterDave Offline OP
Tampa
OK, guys and gals, here it is!
As many of you already know, Dan, aka "Performance Only", has been in the hospital for the past six weeks, suffering from an extremely bad case of pneumonia. It was so bad, one of his lungs collapsed, and has been breathing with the aid of a ventilator for weeks. It has been touch and go for quite a while, but Dan is a fighter, and the doctors say that his prognosis is improving with each passing day.
Many of you with big hearts who don't know Dan, and those who know him have asked how they can help our Mopar brother. Instead of just accepting donations, it was Dan's idea to give back, by leveraging his expertise as a master engine guru to build a 500"+ big block wedge engine for one lucky winner that helped him in his time of need.
Here is what the lucky winner will get:
One big block Mopar wedge *507” street/strip pump gas combination
Specs as follows:
Compression Ratio: 10.5:1
Stock RB block: Fully prepped, squared, decked, ARP studs, sonic checked, align honed
Camshaft: Hydraulic Roller, custom grind
Lifters: Morel Hydraulic roller
Pistons: Diamond forged
Piston rings: Total Seal CR series moly rings
Connecting Rods: Molnar Technologies
Crankshaft: Molnar Technologies or other TBA,forged
Cylinder Head: New aluminum, 84 cc chamber, with Isky valve springs
Rocker Arms: Hughes Engines, aluminum 1.5 ratio with steel Hughes hold down kit
Pushrods: Manton or Trend Performance
Bearings: Clevite rods and mains, Durabond cam bearings
Aluminum Intake manifold, TBA
Oil Pan: 7 qt performance style pan with pick up
Oil pump: Melling H series oil pump
Break in: Engine will be broken in, and has the option to be dynoed, or may be dynoed if we have a shop stepping up to do so.
* Due to the nature of this engine build, some minor adjustments may be made, such as , engine could end up at either 500”, up to 512”. The good will of the manufacters and shops helping with the parts supply , can or may dictate the final crank and engine size. Engine will be intake to pan, carb not included. Other options and changes may be made by discussing the final build with Dan Costello.
There have been many folks stepping up to help assist with this project, and should be appropriately noted:
Competition Wedge Engines, Marsh Performance, Molnar Technologies, Diamond Racing Pistons, Hughes Engines, Clevite bearings, Total Seal Piston Rings, FA Products of New York, Morel Lifters, as well as several others to be added and mentioned shortly. We will make a special post and follow up recognizing them individually. Without them, this raffle, and help for one of our Mopar brothers would be impossible.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: DusterDave] #1620808
05/16/14 09:58 PM
05/16/14 09:58 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I would be darned careful mentioning " raffle " on Paypal.
DO NOT write raffle in your message.......trust me on this.
That being said , and despite my small block tendencies , deal me in.
paypal incoming.
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: tubtar] #1620809
05/16/14 11:06 PM
05/16/14 11:06 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
5.53 @ 125 1/8th on the launch control..more left in her!
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: tubtar] #1620810
05/16/14 11:07 PM
05/16/14 11:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have no use for a big block. Money sent.
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: justinp61] #1620811
05/16/14 11:15 PM
05/16/14 11:15 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Third entry from the "distributer in the proper rearward location gang" Thanks for your great deal on my rotating assy Dan! ....along with info over the years. Get well soon!
Jay
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: J_BODY] #1620812
05/16/14 11:27 PM
05/16/14 11:27 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I'm entered, as much as I'd like the motor if I win tell Dan to put the money in his pocket. Hope you're out of the hospital soon Dan!Dave
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: quickd100] #1620813
05/16/14 11:56 PM
05/16/14 11:56 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I'm not very lucky but, good cause
Give it a try
Get well soon Dan
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: quickd100] #1620814
05/16/14 11:58 PM
05/16/14 11:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll have the wife enter one tomorrow and another
a week or so later.. I'm assuming these will be regular
raffle type tickets with 2 tickets with the number
like the person would keep one... thats the reason
for the time between tickets(I dont want multiple
numbers back to back)... thats just me.....
Get well Dan
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: MR_P_BODY] #1620815
05/17/14 12:15 AM
05/17/14 12:15 AM
Tampa
Tampa
Get well Dan
We will be filling the oil pan with equal sized pieces of paper with names on them, not tickets with numbers. That is why we require the full name of the entrant.
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: DusterDave] #1620816
05/17/14 12:29 AM
05/17/14 12:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Get well Dan
Got ya
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: MR_P_BODY] #1620817
05/17/14 10:19 AM
05/17/14 10:19 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
I'm in,paypal will be sent this afternoon,after work.Get well Dan
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: meepmeep70] #1620818
05/17/14 02:34 PM
05/17/14 02:34 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Speaking for myself, I don't have a PP account and I never will. An alternate method to buy a ticket might elicit more donations.
In lieu of that, is there a bank account set up to help with Dan's expenses?
Best wishes and get well, Dan.
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: 64Post] #1620819
05/17/14 03:15 PM
05/17/14 03:15 PM
Tampa
Tampa
Somebody correct me if I'm wrong about this, but I thought it was possible to send money to a paypal account without having to create your own paypal account.
Paypal is the way we are collecting the $50.00 entry for the engine raffle. If you have a personal gripe against paypal, for whatever reason, I don't know what to tell you. I don't want to create multiple ways of people sending money for entries, because it will become too much for me to manage. I can't keep changing the rules, just to make someone happy. For those of you who just want to send a donation to Dan, I will try to find out Dan's mailing address, and you can send it through the mail.
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: DusterDave] #1620820
05/18/14 03:06 PM
05/18/14 03:06 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Would it be too much to ask to make sure the crank is drilled for a stick shift application
Gus
64 Plymouth Savoy
Dana 60
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: fourgearsavoy] #1620821
05/18/14 04:36 PM
05/18/14 04:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Gus
Why? I don't run a four speed.
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: justinp61] #1620822
05/18/14 07:48 PM
05/18/14 07:48 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
I'll be in. Just need to wait until Wed. Payday. Dan has always given so much to the board. Never forget the first time I met met him. In Jimmy's trailer at the Nats, measuring his first Hemi for the Dart for Firecore Wires. Actually, first time I met Jimmy as well. Truly great guy.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: DusterDave] #1620823
05/19/14 11:12 PM
05/19/14 11:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I've done it for eBay purchases, but don't know how it can be done in this situation.
Nothing on PayPal's web site seems to cover this, other than providing this option for business accounts where customers are making online purchases.
I'm ready to purchase a couple of tickets, but don't know exactly how to do it under the circumstances.
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: DusterDave] #1620824
05/20/14 08:03 AM
05/20/14 08:03 AM
Weatherford, Texas
RapidusMaximus Online content
RapidusMaximus  Online Content
Weatherford, Texas
Thanks Dave, I too fall into the no PP crowd but would be glad to snail mail a couple of entries.
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: BradH] #1620825
05/20/14 04:29 PM
05/20/14 04:29 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
send me money Brad and I'll put your name in for ya, god knows, Dan will get you an engine together before you'll get yours done
Re: BENEFIT ENGINE RAFFLE FOR DAN (PERFORMANCE ONLY) [Re: sixpackgut] #1620826
05/20/14 06:57 PM
05/20/14 06:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This is not the outcome we were hoping for.
RIP
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
