Hood Scoops, Rain and open trailers #1620514
05/15/14 10:56 PM
05/15/14 10:56 PM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
Do you any of you guys seal off your hood scoop when pulling your car down the road?? I have a Six Pack scoop on mine and would like to seal it up while towing it.... Any suggestions
Thanks!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Hood Scoops, Rain and open trailers [Re: QTR MILR] #1620515
05/15/14 11:14 PM
05/15/14 11:14 PM
baldwinsville new york
a493demon Online content
a493demon  Online Content
I just use a carb hat.
tried plastic rap that blew off in a mile or 2 .lol
Re: Hood Scoops, Rain and open trailers [Re: QTR MILR] #1620516
05/15/14 11:32 PM
05/15/14 11:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to seal mine with a scoop plug when I hauled
on a open trailer.. you could make one out of foam
rubber to fit the opening
Re: Hood Scoops, Rain and open trailers [Re: MR_P_BODY] #1620517
05/16/14 01:36 AM
05/16/14 01:36 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
if you look hard you'll see one on my 6 pak. it's made of close cell foam that's been covered with a vinyl weatherproof covering. works great.
Re: Hood Scoops, Rain and open trailers [Re: MR_P_BODY] #1620518
05/16/14 01:38 AM
05/16/14 01:38 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Carb hat and soft foam blocks wrapped in a thick plastic (bag or whatever) that fit fairly tightly into the scoop openings. Been all over including cross-country in rain & snow with that, and not a drop of water gets inside.
Re: Hood Scoops, Rain and open trailers [Re: topside] #1620519
05/16/14 07:33 AM
05/16/14 07:33 AM
Ft. Wayne, IN.
Q
QTR MILR Offline OP
QTR MILR  Offline OP
Q
Ft. Wayne, IN.
Thanks guys!! I bought some foam to cut down. Now I gotta get the Wifey to sew a cover over it for me!!
Scott
Re: Hood Scoops, Rain and open trailers [Re: QTR MILR] #1620520
05/16/14 10:22 AM
05/16/14 10:22 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I used to use two of the aero-scoop plugs for my 6pak hood, plus I used a carb hat.
Re: Hood Scoops, Rain and open trailers [Re: ProSport] #1620521
05/16/14 10:30 AM
05/16/14 10:30 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^This is what I use^^^
Re: Hood Scoops, Rain and open trailers [Re: racerx] #1620522
05/16/14 11:41 AM
05/16/14 11:41 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
When i tow the street car it has an air filter on it.
The race car has a foam insert that goes in the scoop.It is painted to match the car.
