Burst Plate(s) on Tunnel Ram #1620291
05/15/14 12:29 PM
05/15/14 12:29 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Hey tunnel ram guys!
Should I be installing a burst plate on my indy tunnel ram? Should there be one in each end of the plenum? I'd rather spend $200 now than have to repair carburetors, etc.
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620292
05/15/14 12:57 PM
05/15/14 12:57 PM
I have never seen it done or heard about it being done. Burst panels are for blower applications.
Re: Burst Plate(s) on Tunnel Ram [Re: ] #1620293
05/15/14 01:34 PM
05/15/14 01:34 PM
detroit area
moderncylinder Offline
detroit area
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620294
05/15/14 02:42 PM
05/15/14 02:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Yes you should.
RIP Monte Smith
Re: Burst Plate(s) on Tunnel Ram [Re: CompWedgeEngines] #1620295
05/15/14 03:58 PM
05/15/14 03:58 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I thought these looked nice:
http://www.bmfperformance.com/bmf-burst-panel/
I have to call and see what physical dimensions are.
Should I run one on each end of the plenum (Indy tunnel ram) or should I put one in between the carbs on the top plate? I think there is enough room to run one.
My reason for even thinking about this was seeing a picture of an Indy tunnel ram with the front of the plenum all welded up.
Thank you for your insight.
Re: Burst Plate(s) on Tunnel Ram [Re: ] #1620296
05/15/14 06:08 PM
05/15/14 06:08 PM
Virginia
64HemiSavoy Offline
64HemiSavoy  Offline
Virginia
Obviously haven't kept up with the SS/AH crowd? Lots of them run burst panels.
Re: Burst Plate(s) on Tunnel Ram [Re: moderncylinder] #1620297
05/15/14 10:55 PM
05/15/14 10:55 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
http://www.nitrousproflow.com/products/burst-panels/manifold-pressure-relief-valve.html
Always a good idea
Bob
We use them on our Indy manifold. Not a whole lot of purge area, and I know they have not saved a manifold on some others cars, but better than nothing.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620298
05/16/14 01:24 AM
05/16/14 01:24 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I put a pair on my old Rat Roaster.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Burst Plate(s) on Tunnel Ram [Re: Hemi Allstate] #1620299
05/17/14 01:44 PM
05/17/14 01:44 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thanks for the feedback. I will install them on both ends of the plenum.
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620300
05/17/14 03:18 PM
05/17/14 03:18 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Look at the size of a burst panel, compared to 8 throttle blades wide open.........less area. A burst panel usually only helps a light sneeze when trying to crank. For a big backfire they are useless. What we use on the Pro-Mod cars is plastic bolts for the top plate. If it sneezes it just sheers the bolts, you replace them and away you go.
On a blower car, in addition to burst panel, they also run alum blower studs. So even when it pops panel, it still lifts the blower. You are just hoping the combo of the two keeps it from destroying the intake
Monte
Re: Burst Plate(s) on Tunnel Ram [Re: Hemi Allstate] #1620301
05/17/14 03:35 PM
05/17/14 03:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So if the burst panels are only a part solution, on your rat manifold, why not just mount the entire top panel spring loaded with similar bolts as burst panels, or would preventing linkage wide open throttle bind be too much of an issue/c concern?
Re: Burst Plate(s) on Tunnel Ram [Re: jcc] #1620302
05/17/14 08:43 PM
05/17/14 08:43 PM
Mt. Eden Ky.
Mt. Eden Ky.
That's an interesting idea.
The Rat Roaster was known to have back fire issues, due to puddling fuel. I addressed that as well.
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Burst Plate(s) on Tunnel Ram [Re: Monte_Smith] #1620303
05/17/14 08:56 PM
05/17/14 08:56 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Monte
When you say plastic bolts do mean nylon? I'll look into it.
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620304
05/18/14 02:14 AM
05/18/14 02:14 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Monte
Yes, just use the nylon bolts. Problem solved
Monte
Re: Burst Plate(s) on Tunnel Ram [Re: Monte_Smith] #1620305
05/18/14 09:00 AM
05/18/14 09:00 AM
moparx Offline
moparx  Offline
any recommendations for a maxie intake ?
Re: Burst Plate(s) on Tunnel Ram [Re: moparx] #1620306
07/10/14 11:56 PM
07/10/14 11:56 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Update:
After spending some time with the nylon bolts I decided I didn't like the thought of the top plate popping off the intake. I can see where this might work in some applications however the older style Indy TR top is not one of them IMO.
We ended up putting a CFE (aka BMF) burst plate on each side of the manifold.
Re: Burst Plate(s) on Tunnel Ram [Re: Jeremiah] #1620307
07/11/14 05:40 PM
07/11/14 05:40 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What I do with the plastic bolts, to keep from blowing the top off and destroying linkage or lines, is one of two methods.....One is you can make 4 "tethers" from very small steel cable. Fab up some small brackets at the four corners and it lifts and sets right back down......Two, is at the 4 corners, you install what amounts to a carb stud. Secure the intake top with the plastic bolts and put a spring and nut on the 4 corner studs. You are essentially making the WHOLE top the burst panel.
I know LOTS of people use them, but those small burst panels are pretty much useless. It MIGHT and I repeat MIGHT help you with a small pop when cranking, but chances are still VERY good that even if they do open, you will still taco shell the throttle plates. I would lots rather have to replace some plastic bolts and reseal the top, than try to wrestle bent throttle blades from a carb.......especially a Dominator. If the you bend them bad, you usually have to cut the throttle shafts out to get them out. Then you are out blades AND shafts.
Monte
Re: Burst Plate(s) on Tunnel Ram [Re: Monte_Smith] #1620308
07/11/14 06:40 PM
07/11/14 06:40 PM
Jamie McGrath Offline
I myself am just wondering how effective the burst plates are in the front side and the rear side of the RR intake, seems to me they would be more effective if they were on top of the lid more near the center?
Re: Burst Plate(s) on Tunnel Ram [Re: Monte_Smith] #1620309
07/11/14 09:26 PM
07/11/14 09:26 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Monte
Thank you as always for your insight. My car is a street/strip deal so most of my reasoning for installing the burst plates is for lean backfires when I am warming up the engine (i.e. a cold fall morning putting to the track). As far as the nylon bolts I am having a hard time finding flat allen head (tapered seat) 10-24 machine screws in the harder, UV-proof nylon. I did find some that are made from white nylon however they are quite soft and the cone on the underside of the bolt head is no as large in comparison to it's steel counterpart. Where do you guys buy your nylon bolts? The only place I have found them is home improvement stores and hardware outfits (ACE is the place).
I like the idea of tehers.
Re: Burst Plate(s) on Tunnel Ram [Re: Jamie McGrath] #1620310
07/12/14 12:11 AM
07/12/14 12:11 AM
Mt. Eden Ky.
Mt. Eden Ky.
I cannot answer your question with my own experience, as I have yet to use my RR intake. However, I placed them where they are, as recommended by a board member, with a lot of experience with the RR intakes and modifications to the same.
Mark
1996 Ram 1500 Sport
1968 road runner
