Steering column HELP!!! #1620111
05/14/14 06:41 PM
05/14/14 06:41 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
I took off the steering wheel to change the signal switch and removed these to bolts thinking that would be loosening up the cone like cover. (please see pics) Took the bolts out, noticed nothing happened so I was screwing the bolts back in and there is nothing gripping the bolts. Anybody know what I did wrong??
Re: Steering column HELP!!! [Re: ngpSatellite] #1620112
05/14/14 06:49 PM
05/14/14 06:49 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
upper Collar is turned
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Steering column HELP!!! [Re: ngpSatellite] #1620113
05/14/14 06:50 PM
05/14/14 06:50 PM
Kudakid Offline
Kudakid  Offline
Did you rotate the back portion so it no longer lines up with the cone?
2010 Challenger R/T 2001 Jeep Cherokee 1970 AAR Cuda 1970 T/A
Re: Steering column HELP!!! [Re: azmopar] #1620114
05/14/14 06:54 PM
05/14/14 06:54 PM
own private Idaho
N
N
own private Idaho
thx for your reply what's the right way to line it back up I Turned the outer case but still don't see anything to grab on to,
Re: Steering column HELP!!! [Re: ngpSatellite] #1620115
05/14/14 06:55 PM
05/14/14 06:55 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
lots of times itll slide up a little and u can see where the bosses are for the screws
#NONIKESEVER
Re: Steering column HELP!!! [Re: azmopar] #1620116
05/14/14 07:09 PM
05/14/14 07:09 PM
own private Idaho
N
N
own private Idaho
OK... Thanks so much!!
Re: Steering column HELP!!! [Re: ngpSatellite] #1620117
05/14/14 07:27 PM
05/14/14 07:27 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
let us know what you find
#NONIKESEVER
Re: Steering column HELP!!! [Re: azmopar] #1620118
05/14/14 08:14 PM
05/14/14 08:14 PM
own private Idaho
N
N
own private Idaho
I'm not sure what's going on but there is no bosses that I can see. I jacked the car up and moved the front tires like I was turning and the spindle turns and the cone and collar stay straight like it should. I'm not even sure what the purpose for those two bolts are. when I turn the cone and collar the cone, front collar and lower outer case turn but you can only go to about 2 o'clock (and still no bosses.) That bolt in pic in upper left, when I un screwed the bolt I didn't move anything and just tried to put it back with in a minute so that's why its a bit funny. Maybe its for a column shift car. mines a floor console???
Re: Steering column HELP!!! [Re: Kudakid] #1620119
05/14/14 08:18 PM
05/14/14 08:18 PM
own private Idaho
N
N
own private Idaho
the cone, front collar(pic) and the outer long cover shaft all move together.. I tried to twist them, there all in lockstep.
Re: Steering column HELP!!! [Re: ngpSatellite] #1620120
05/14/14 08:20 PM
05/14/14 08:20 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
try turning the other direction?
#NONIKESEVER
Re: Steering column HELP!!! [Re: azmopar] #1620121
05/14/14 08:50 PM
05/14/14 08:50 PM
own private Idaho
N
N
own private Idaho
Tried moving other direction and nothing. The back cone, front collar and long outer shell all move together. you could actually spin it from the engine bay as well (outer shell sticks out about 5 in on firewall). So if these bolts are to keep the front collar and cone together then they are not separating at all right now and when I eventually put the lower steering column bracket back on that will lock in the outer shell, cone and front collar in place. is the front collar and the cone suppose to move independent of each other when the bolts are out??
Re: Steering column HELP!!! [Re: ngpSatellite] #1620122
05/14/14 09:07 PM
05/14/14 09:07 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
HMMMM ill have to look at one when I get home itll be late when I get home so hang tight,
#NONIKESEVER
Re: Steering column HELP!!! [Re: azmopar] #1620123
05/14/14 09:21 PM
05/14/14 09:21 PM
own private Idaho
N
N
own private Idaho
will do.........thx.. its almost like the bolts for a column shift.. thx for your time.. my switch is coming in tomorrow so no rush!
Re: Steering column HELP!!! [Re: ngpSatellite] #1620124
05/15/14 12:14 PM
05/15/14 12:14 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
you have to remove the circlip on the shaft to remove the collar,did you do that? cant see in the pics.
Re: Steering column HELP!!! [Re: ngpSatellite] #1620125
05/15/14 12:25 PM
05/15/14 12:25 PM
None
71rm23 Offline
71rm23  Offline
None
Just FYI- That bearing in the middle is stilll available from the factory
Re: Steering column HELP!!! [Re: 71rm23] #1620126
05/15/14 04:40 PM
05/15/14 04:40 PM
own private Idaho
N
N
own private Idaho
Hey there... thanks for the replies... I did take the locking clip off and it did not budge, both cone and front collar(were you mount the switch) seemed to be fused together, when I twist the front collar everything moves(except Steering wheel spindle of coarse) the collar cone and long casing that goes through the fire wall all rotate together.
I tried to twist the front collar and back cone in opposite directions to get it to break free and nothing.
that bearing looks good but (spindle moves smoothly) when I took the locking ring off I tired to pull off front collar and nothing...front collar and bearing are stuck together. When you look behind the front collar I see nothing .. just doesn't make sense right now... like there is not a purpose for the bolts (maybe the slots were for a column shift car) last owner had the interior completely redone 10 years ago so maybe someone just stuck them in there just b/c...must have been a chevy guy .. .... long shot)
there was no noise of a brocket or bosses falling when I took the bold out and I tried to put back within a minute and I didn't move anything..
Re: Steering column HELP!!! [Re: ngpSatellite] #1620127
05/15/14 04:44 PM
05/15/14 04:44 PM
own private Idaho
N
N
own private Idaho
ref pic of front collar cone and long case
Re: Steering column HELP!!! [Re: ngpSatellite] #1620128
05/15/14 05:04 PM
05/15/14 05:04 PM
own private Idaho
N
N
own private Idaho
pic2
Re: Steering column HELP!!! UPDATE [Re: ngpSatellite] #1620129
05/15/14 07:59 PM
05/15/14 07:59 PM
own private Idaho
N
N
own private Idaho
just found a parts breakdown and it shows two retaining nuts. just have to slide them back into view and lockdown. Thanks for the help everyone
Re: Steering column HELP!!! [Re: ngpSatellite] #1620130
05/15/14 08:27 PM
05/15/14 08:27 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
I have my '73 newport column apart on my coffee table as we speak.
On the lower collar there are three round bosses sticking up and one goes in between the walled in areas of the slot for the wires and the turn signal stick on the upper collar.
The collars fit together pretty snug as does the bearing on the shaft, after removing the screws I tapped on the shaft with a brass hammer while pulling on the upper collar and it popped right apart .
[image][/image]
