Best Rockers for BB Victor Heads #1620044
05/14/14 11:50 AM
05/14/14 11:50 AM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
Were building a 493 BB for a customer. Its just a bracket engine. We have the BB Edelbrock Victor heads on it and I'm curious as to who has what kind of luck with various rockers. We like Jesel but they arent in the budget and Crane is about 4 months out.
J.C. Childress (434) 665-9541
Re: Best Rockers for BB Victor Heads [Re: JC Childress] #1620045
05/14/14 11:57 AM
05/14/14 11:57 AM
tboomer Offline
tboomer  Offline
J.C. I like my Hughes rockers.
Re: Best Rockers for BB Victor Heads [Re: tboomer] #1620046
05/14/14 12:02 PM
05/14/14 12:02 PM
Big Island ,VA
Big Island ,VA
We tried some of those on another project identical to this and broke a few... :-( around 750 lbs open....not a ton but they broke. Went to Jesel and havent had any issues.
Re: Best Rockers for BB Victor Heads [Re: JC Childress] #1620047
05/14/14 03:39 PM
05/14/14 03:39 PM
Cab_Burge Online work
Cab_Burge  Online Work
Where the ones you broke the heat treated ones that Hughes sells now with the blue dots on them for the heat treated identification ?
Re: Best Rockers for BB Victor Heads [Re: JC Childress] #1620048
05/14/14 03:49 PM
05/14/14 03:49 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
I used Harland Sharp on mine, so far so good. Solid roller .674 lift 1.6s. That said, they are close to the valve cover rail on the pushrod side so had to clearance valve cover flange to slide over studs without hitting rockers. I doubt you could use stamped steel covers without interference.I used fabricated aluminum covers.
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: Best Rockers for BB Victor Heads [Re: MoParFish] #1620049
05/14/14 04:26 PM
05/14/14 04:26 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would recommend T&D rockers. The single shaft T&D rockers should work real good on that combo.
http://www.tdmach.com/
(775) 884-2292
Re: Best Rockers for BB Victor Heads [Re: Biginchmopar] #1620050
05/14/14 04:32 PM
05/14/14 04:32 PM
Big Island ,VA
Big Island ,VA
The ones that our customer used were before the heat treated ones that Hughes has, at least to my knowledge.
Re: Best Rockers for BB Victor Heads [Re: JC Childress] #1620051
05/14/14 05:07 PM
05/14/14 05:07 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Does Crane offer them for the Victors now with offset intakes?
Re: Best Rockers for BB Victor Heads [Re: MoParFish] #1620052
05/14/14 05:47 PM
05/14/14 05:47 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
If Crane doesn't make them a whole lot stronger than what they have now, they're not going to hold up to big spring pressure, either.
Re: Best Rockers for BB Victor Heads [Re: PorkyPig] #1620053
05/14/14 06:28 PM
05/14/14 06:28 PM
Big Island ,VA
Big Island ,VA
Were gonna use T&D. Customer decided to step up. Thanks for all the input.
Re: Best Rockers for BB Victor Heads [Re: JC Childress] #1620054
05/15/14 10:59 PM
05/15/14 10:59 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Contact Sheldon at T&D if you don't go through a dealer.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Best Rockers for BB Victor Heads [Re: Dads426] #1620055
05/16/14 02:05 PM
05/16/14 02:05 PM
Big Island ,VA
Big Island ,VA
Thanks. We have an acct at T & D and I have dealt with Sheldon for years. Hes a good guy.
Re: Best Rockers for BB Victor Heads [Re: JC Childress] #1620056
05/16/14 08:55 PM
05/16/14 08:55 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have T&D's on the max wedge victors. I think they are 0.725" offset for the max wedge ports. I think standard victors use a 0.600" offset rocker arm (Intakes)?
