gear lube or atf in a 833 4 speed #1619810
05/13/14 04:42 PM
05/13/14 04:42 PM
United states wisconsin
bigblockbryan Offline OP
okay i was googling capcity for my 833 4 speed and some one said to run atf. In them is this a good idea or should i just get 80-90.I know in the new fwd drive stuff they use atf my 4 speed is a 71 23 spline is correct capcity 4 qarts thanks.
Re: gear lube or atf in a 833 4 speed [Re: bigblockbryan] #1619811
05/13/14 04:45 PM
05/13/14 04:45 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
This has been a hot topic in the past. We use 90w gear oil.
Re: gear lube or atf in a 833 4 speed [Re: dustergirl340] #1619812
05/13/14 04:46 PM
05/13/14 04:46 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
90wt. Gotta agree.
Re: gear lube or atf in a 833 4 speed [Re: bigblockbryan] #1619813
05/13/14 04:48 PM
05/13/14 04:48 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I currently am using Passon Perf lube for my 18 spline. It is red like ATF. I might switch back to the old Stalube 85-90 GL-4 gear oil.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: gear lube or atf in a 833 4 speed [Re: bigblockbryan] #1619814
05/13/14 05:08 PM
05/13/14 05:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And some of us who tried both prefer synthetics even though the 833 gurus recommend against it.
Re: gear lube or atf in a 833 4 speed [Re: bigblockbryan] #1619815
05/13/14 05:15 PM
05/13/14 05:15 PM
Georgia
Steve Bryant Offline
Georgia
We used 90W in my Cuda
Re: gear lube or atf in a 833 4 speed [Re: Steve Bryant] #1619816
05/13/14 05:23 PM
05/13/14 05:23 PM
usa
smos001 Offline
smos001  Offline
usa
GL4 ONLY. I talked to valvoline tech support and they stated that GL5 eats yellow metal and should not be uses in mopar A833.
they suggested synchromesh.
Re: gear lube or atf in a 833 4 speed [Re: smos001] #1619817
05/13/14 05:27 PM
05/13/14 05:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
GL5 only eats yellow metal if sulphur is used in the fluid as an anti-friction additive. It shouldn't be used in any trans because the anti-friction additives defeat the purpose of synchros.
Re: gear lube or atf in a 833 4 speed [Re: bigblockbryan] #1619818
05/13/14 05:31 PM
05/13/14 05:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
90 wt....end of story
Re: gear lube or atf in a 833 4 speed [Re: John_Kunkel] #1619819
05/13/14 05:35 PM
05/13/14 05:35 PM
70sixpkrt Offline
70sixpkrt  Offline
I heard Gl-5 does not go good with the Syncro Rings. I get 85-90 GL4 and 80-90 GL5 mixed up all the time. I think 80-90 GL5 is for the rear diff. Had to edit my previos post.
4-speed
3:54 Dana
Re: gear lube or atf in a 833 4 speed [Re: 70sixpkrt] #1619820
05/13/14 06:56 PM
05/13/14 06:56 PM
Vallejo, CA
ditchdrift Offline
ditchdrift  Offline
Vallejo, CA
syncromesh fluid. best working fluid i have found.
Re: gear lube or atf in a 833 4 speed [Re: 70sixpkrt] #1619821
05/13/14 06:56 PM
05/13/14 06:56 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Most like the Passon, redline MTF, or synchromesh fluids. You can run ATF if you drive in cold weather I wouldn't use it in warm weather.
Re: gear lube or atf in a 833 4 speed [Re: ademon] #1619822
05/13/14 09:47 PM
05/13/14 09:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
90W in my 65 4 speed.It had syncros put in it in 69 and thats it.It came with gear oil so thats what it runs.Rocky
Chrysler Firepower
Re: gear lube or atf in a 833 4 speed [Re: bigblockbryan] #1619823
05/13/14 10:39 PM
05/13/14 10:39 PM
tucson az
frank Offline
frank  Offline
tucson az
I use Passion's oil in mine and it does not shift well. I'm going to switch to the 90 weight next time
Re: gear lube or atf in a 833 4 speed [Re: frank] #1619824
05/13/14 11:10 PM
05/13/14 11:10 PM
El Cerrito Ca.
gregn96cuda Offline
gregn96cuda  Offline
El Cerrito Ca.
My trans guy used 30 weight motor oil in my hemi 4 speed. It shifts fine for me.
Re: gear lube or atf in a 833 4 speed [Re: gregn96cuda] #1619825
05/13/14 11:36 PM
05/13/14 11:36 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
My vote is for Jamie Passon's elixr. Call him up!! I tried Pennzoil Synchromesh and soon regretted it.
I was out rowin 4 Monday morning and loving every minute of it!
Common sense is a flower that does not grow in everybody's garden
Re: gear lube or atf in a 833 4 speed [Re: gregn96cuda] #1619826
05/13/14 11:38 PM
05/13/14 11:38 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
What's different about the syncros in an 833 from those in a T-56?
Tremec told me to run ATF3 in my T-56
**Photobucket sucks**
Re: gear lube or atf in a 833 4 speed [Re: 70Cuda383] #1619827
05/14/14 12:01 AM
05/14/14 12:01 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The 833 is traditional brass ring, single friction surface. The brass rings have grooves in them to ride on the cones of the speed gears and the rings cut through the oil film and speed match the gear when selected to.
The T56 uses a a fiber type friction material on everything except reverse. Similar in appearence/theory of operation to the clutch plate friction material in an automatic transmission. The thin ATF flows better and the friction material pushes it out the way when selected to.
Re: gear lube or atf in a 833 4 speed [Re: 135sohc] #1619828
05/14/14 12:32 AM
05/14/14 12:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Isn't the factory service manual the authority on this? Here is what the FSM says for 4-speed transmissions:
"During cold weather, if shift effort becomes extremely high, transmission should be drained and refilled with Multi-Purpose Gear Lubricant SAE 80 or SAE 90, as defined by MIL-L-2105B or with automatic transmission fluid types labeled "Dexron Automatic Transmission Fluid or Chrysler Automatic Transmission Fluid AQ-ATF-2848A" available under Part Number 1843314. Automatic transmission Fluid should be replaced with Multi-Purpose Gear Lubricant SAE 140 in warm weather. NO OTHER LUBRICANTS SHOULD BE USED."
SAE Gear Oil 140 IS NOT EQUIVALENT in viscosity to SAE Engine Oil 140.
But SAE Gear Oil 90 IS EQUIVALENT in viscosity to SAE Engine Oil 50 according to this chart:
Re: gear lube or atf in a 833 4 speed [Re: kentj340] #1619829
05/14/14 02:50 AM
05/14/14 02:50 AM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
I've tried both. The old 833 shifted better with ATF but leaked a little.
