Re: gear lube or atf in a 833 4 speed
[Re: bigblockbryan]
#1619813
05/13/14 04:48 PM
05/13/14 04:48 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
I currently am using Passon Perf lube for my 18 spline. It is red like ATF. I might switch back to the old Stalube 85-90 GL-4 gear oil.
[Re: bigblockbryan]
#1619814
05/13/14 05:08 PM
05/13/14 05:08 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
And some of us who tried both prefer synthetics even though the 833 gurus recommend against it.
[Re: bigblockbryan]
#1619818
05/13/14 05:31 PM
05/13/14 05:31 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: ademon]
#1619822
05/13/14 09:47 PM
05/13/14 09:47 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
90W in my 65 4 speed.It had syncros put in it in 69 and thats it.It came with gear oil so thats what it runs.Rocky
Chrysler Firepower
[Re: gregn96cuda]
#1619825
05/13/14 11:36 PM
05/13/14 11:36 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
My vote is for Jamie Passon's elixr. Call him up!! I tried Pennzoil Synchromesh and soon regretted it. I was out rowin 4 Monday morning and loving every minute of it!
Common sense is a flower that does not grow in everybody's garden
[Re: gregn96cuda]
#1619826
05/13/14 11:38 PM
05/13/14 11:38 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
What's different about the syncros in an 833 from those in a T-56?
Tremec told me to run ATF3 in my T-56
**Photobucket sucks**
[Re: 70Cuda383]
#1619827
05/14/14 12:01 AM
05/14/14 12:01 AM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
The 833 is traditional brass ring, single friction surface. The brass rings have grooves in them to ride on the cones of the speed gears and the rings cut through the oil film and speed match the gear when selected to. The T56 uses a a fiber type friction material on everything except reverse. Similar in appearence/theory of operation to the clutch plate friction material in an automatic transmission. The thin ATF flows better and the friction material pushes it out the way when selected to.
[Re: 135sohc]
#1619828
05/14/14 12:32 AM
05/14/14 12:32 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
Isn't the factory service manual the authority on this? Here is what the FSM says for 4-speed transmissions:
"During cold weather, if shift effort becomes extremely high, transmission should be drained and refilled with Multi-Purpose Gear Lubricant SAE 80 or SAE 90, as defined by MIL-L-2105B or with automatic transmission fluid types labeled "Dexron Automatic Transmission Fluid or Chrysler Automatic Transmission Fluid AQ-ATF-2848A" available under Part Number 1843314. Automatic transmission Fluid should be replaced with Multi-Purpose Gear Lubricant SAE 140 in warm weather. NO OTHER LUBRICANTS SHOULD BE USED."
SAE Gear Oil 140 IS NOT EQUIVALENT in viscosity to SAE Engine Oil 140.
But SAE Gear Oil 90 IS EQUIVALENT in viscosity to SAE Engine Oil 50 according to this chart:
