I just picked up an 04, 3500, 24valve, 6 speed, 3.73 gears and need to put an exhaust brake on it. Which one are you guys using? I have a Jacobs on my '95 that works great. But I was looking on the bag at what's available and found Jacobs, Pacbrake, BullyDog, and Banks. Jacobs has a vacuum pump that needs to be installed. BullyDog has an aircompressor that needs to be installed. The others I'm not exactly sure what needs to be done. Who has had the best luck with what? I'm really not keen on putting a vac. pump on the engine to run the brake nor have an aircompressor to run the valve. I guess this is the way it is though.
