NOS Hemi Plug Wire Set Questions #1618906
05/11/14 08:41 PM
05/11/14 08:41 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Picked up a set of nos Hemi plug wires # 3420881 from a former Plymouth service manager that had bought these new back in 1970. First question is the lack of a coil wire, did this need to be ordered as a separate part number? Second,3 of the wires are date coded 1Q 70 and the other 5 are dated 4Q 69, would you find date codes on an original car like this or would they all be the same date code. Just wondering if back in the day they just used what ever wires they had left to make up a set to sell over the counter as a replacement part. Just want to know if these would be correct if used on a oem judged car.
Dan.
Re: NOS Hemi Plug Wire Set Questions [Re: mopar4ya] #1618907
05/11/14 10:04 PM
05/11/14 10:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes.
NOS sets I've had included the coil wire, and it's unique, white lettering instead of yellow, and the boots are deep brick red.
Re: NOS Hemi Plug Wire Set Questions [Re: ScottSmith_Harms] #1618908
05/11/14 10:20 PM
05/11/14 10:20 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Yes.
Yes you would find date codes like this OR yes they would all be the same?
Dan.
Re: NOS Hemi Plug Wire Set Questions [Re: mopar4ya] #1618909
05/11/14 10:23 PM
05/11/14 10:23 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
They didn't always match but were typically close (1 quarter apart, etc.)
Re: NOS Hemi Plug Wire Set Questions [Re: ScottSmith_Harms] #1618910
05/11/14 10:28 PM
05/11/14 10:28 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Thanks Scott!
Re: NOS Hemi Plug Wire Set Questions [Re: mopar4ya] #1618911
05/12/14 12:55 PM
05/12/14 12:55 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
the majority of all the nos plug wire sets i have do have at least 2 different quarter dates, with hemis i have seen up to 4 different quarter dates, with 3 seeming to be the most common
and yes as scott said, the coil wires are included and have white lettering
if you get lucky theyll have 1 red boot too
Re: NOS Hemi Plug Wire Set Questions [Re: TONY_DAGOSTINO] #1618912
05/12/14 09:15 PM
05/12/14 09:15 PM
western PA
mopar4ya Offline OP
mopar4ya  Offline OP
western PA
Back in the day, could you order a coil wire that would be the same as the one that comes in the sets. Just wondering if I can find a nos coil wire by part number.
Dan.
Re: NOS Hemi Plug Wire Set Questions [Re: mopar4ya] #1618913
05/13/14 04:20 PM
05/13/14 04:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Dan.
I don't think NOS plug wires were individual cylinder based ( meaning 1 pt # serviced all 9 wires ,,aka cut to fit)
