Re: Adjusting roll out on chassis car.
[Re: Jonnyj00]
#1618678
05/11/14 09:42 AM
05/11/14 09:42 AM
Posts: 9,873 MI, usa
dvw
MI, usa
I have a chassis car that has mustang 2 front suspension on it and I was wanting to try and adjust the car's roll out. I have been having trouble with red lighting and was wanting to try off setting the front tires a bit. I haven't tried adjusting anything yet I wanted to ask somebody that has some experience with this before I messed with it. I have tried adjusting my trans brake button all the way out, letting some air out of the tires and lowering the launch rpm. I am still having trouble with red lights.. Any help/advice would be much appreciated
I would try taller front tires and see if that helps first. The mod your talking about would require the lower and upper control arm locations to be moved forward or rearward. Have you tried a blinder? I'm assuming we are talking .500 full tree. How bad are the red lights? Doug
[Re: dvw]
#1618679
05/11/14 10:34 AM
05/11/14 10:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Like Doug said... if you want to stagger the front end you have to cut that whole assm off the chassis and move it.. normally the right side is moved rearward to keep it in the lights longer.. mine is moved 3/4"
[Re: '72CudaRacer]
#1618683
05/11/14 03:44 PM
05/11/14 03:44 PM
Posts: 161 SE Iowa
Jonnyj00
SE Iowa
The car doesn't seem to transfer very well to me so maybe that could contribute some? Here is a video of a pass I made last year. Im not sure it will work but ill try. http://youtu.be/Gw7mN8X_JIAThis is a pass I made when I was just trying to get used to the car so I try to stage a little more careful than this lol.
[Re: Jonnyj00]
#1618688
05/11/14 10:23 PM
05/11/14 10:23 PM
MR_P_BODY
Last year before we had the shallower pan we had to raise the front suspension of the car a bit so that the oil pan had some clearance. We did it by adjusting the adjusters on the coil springs. Would that cause this problem?
Yes... you took away font end travel
[Re: Jonnyj00]
#1618690
05/11/14 10:44 PM
05/11/14 10:44 PM
MR_P_BODY
Ok I will definitely lower that back down. Is there a way to know how far to go or just a test and try deal?
Thanks guys when it comes to this race suspension I have little to no idea!
Are you using struts.. if so whats the travel
[Re: MR_P_BODY]
#1618692
05/12/14 12:37 AM
05/12/14 12:37 AM
Posts: 161 SE Iowa
Jonnyj00
SE Iowa
I know they are coil overs but i am not sure on the travel they were on the car when we got it.
It also has cables that limit the front end travel. So I need to check that also.
[Re: Jonnyj00]
#1618693
05/12/14 01:07 AM
05/12/14 01:07 AM
MR_P_BODY
So you have a coil over shock... lower the front down and loosen the limiters till you have problems
[Re: MR_P_BODY]
#1618694
05/12/14 02:29 AM
05/12/14 02:29 AM
Posts: 2,864 IN
Irun5snd8th
IN
Follow the advice of others here and then get one of these Just N Time transbrake button
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#1618695
05/12/14 07:44 AM
05/12/14 07:44 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The first thing I saw in the vid was the right front tire pop out of the beams on the hit. Get some travel into the front end, soften the front shocks and see what happens. You need three inch or more rise I would think. If you still can't keep the front in the beams and roll through for max roll out, then if possible raise the ladder bar front hole as far as you can to change the pitch rotation of the car. If you go above what they call a neutral line with the front ladderbar hole, it pushes the nose down for an instant before allowing it to rise. I could change mine by .02 this way. Hopefully it will work for you like it did for me.
[Re: gregsdart]
#1618696
05/13/14 01:37 AM
05/13/14 01:37 AM
gregsdart
What ETs are you running? At some point it gets really hard to leave off a last yellow, the car is just plain too fast. One idea would be a VERY loose converter and a low rpm two step.
