ramcharger decode #1618533
05/10/14 09:56 PM
05/10/14 09:56 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
can someone decode this 78 ramcharger. vin.
A10BD8S260294. thanks. wanted to make sure it was correct size motor etc. saw the "S" in serial number and was wandering if that stood for special like a LIL Red. thanks
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: ramcharger decode [Re: hulmule] #1618534
05/10/14 10:15 PM
05/10/14 10:15 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
A - 4 wheel drive SUV
1 - half ton dodge
0 - Ramcharger
B - 6,001 lbs to 10,000 lbs
D - 440-1 V8
8 - 1978
S - Warren, Michigan
260294 is the Sequence Number
Re: ramcharger decode [Re: 98RAM1500] #1618535
05/10/14 10:20 PM
05/10/14 10:20 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Thanks just wanted to verify it was a 440. what tells you its options like if it was a macho etc
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: ramcharger decode [Re: hulmule] #1618536
05/12/14 01:59 PM
05/12/14 01:59 PM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
Check for 2 things.
First, check top of radiator support on right to see if core support tag is there. This will give just the basic of basics like color and paint procedure for 1978.
Second, Check under side of hood for the equipment label. This will denote majority of standard and optional equipment. 50/50 shot on this one still being there.
Please register your Dodge truck here 1972-1980 Dodge truck registry
