904 transmission #1617666
05/08/14 01:23 PM
05/08/14 01:23 PM
Sherwood Park, AB, Canada
faroutman Offline OP
super street
super street
Hi all,
The transmission in my Barracuda won't go into second gear.
Shifts from first to drive, but skips second. Won't mesh manually either??
Am I going to have to pull out the trans to fix it?
Anyone ever encounter such an issue?
Any thoughts, suggestions, or ideas are greatly appreciated.
Re: 904 transmission [Re: faroutman] #1617667
05/08/14 03:30 PM
05/08/14 03:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Does it have the kickdown linkage removed or way out of adjustment?
Pull the pan and look for a metal bar about 3" long. If you find it it is the strut for the front band. If you caught it early it may not have ruined the surface of the front drum and you can reassemble it.
Re: 904 transmission [Re: faroutman] #1617668
05/09/14 06:05 AM
05/09/14 06:05 AM
Any thoughts,
before pulling the pan I'd check the setting on the kickdown band. I ain't sayin the strut is still in place but if it ain't you'll know it when you check the adjuster
Re: 904 transmission [Re: RapidRobert] #1617669
05/09/14 07:13 PM
05/09/14 07:13 PM
super street
super street
Thanks for the tips fella'a.
Hopefully be checking into it this weekend.
Re: 904 transmission [Re: faroutman] #1617670
05/12/14 06:23 PM
05/12/14 06:23 PM
Right here
HP2 Offline
HP2  Offline
Right here
Funny, exactly the same thing happened to me last weekend. I guess something has made the adjuster come loose but I had no time to check. With a little luck it will be possible to put the band back if you take down the valve body...
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
