Re: 904 transmission
[Re: faroutman]
#1617667
05/08/14 03:30 PM
05/08/14 03:30 PM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
Does it have the kickdown linkage removed or way out of adjustment?
Pull the pan and look for a metal bar about 3" long. If you find it it is the strut for the front band. If you caught it early it may not have ruined the surface of the front drum and you can reassemble it.
[Re: faroutman]
#1617670
05/12/14 06:23 PM
05/12/14 06:23 PM
Posts: 523 Right here
HP2
Right here
Funny, exactly the same thing happened to me last weekend. I guess something has made the adjuster come loose but I had no time to check. With a little luck it will be possible to put the band back if you take down the valve body...
70 W100 Power Wagon. 318 4-spd 70 Sport Fury 440 2dr HT 71 Duster 340 71 Charger Super Bee - 383/727 72 Charger "Sabotage" - 440/727 - Street/Strip 78 Warlock in beautiful patina
