Rods #1616940
05/06/14 12:41 PM
05/06/14 12:41 PM
iowa
copchaser Offline OP
iowa
I'm putting together a 572. Looking at rods. Looking for pros and cons of aluminum rods and steel rods. This will not be a torbo of a blower motor. Might run a 250 shot of spray as a insurance policey.
Re: Rods [Re: copchaser] #1616941
05/06/14 07:58 PM
05/06/14 07:58 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
I run GRP aluminum in my 572.... Run em 500 passes and toss em and put in a new set..I shift at 6800 also. They key is get the motor good and warm then let it heat soak for a while before the 1st pass of the day and the will give good service..I have a brand new set of GRP pro series rods 6.760 long if interested...Paid $1250 for them will take $750
Re: Rods [Re: sc301v] #1616942
05/06/14 08:31 PM
05/06/14 08:31 PM
dogdays Offline
dogdays  Offline
Crower or Oliver.
R.
Re: Rods [Re: copchaser] #1616943
05/07/14 10:34 AM
05/07/14 10:34 AM
an8sec70cuda Offline
Oliver steel rods in my 572" hemi. 850 hp or so on motor plus another 200 (for now) from a plate.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Rods [Re: copchaser] #1616944
05/07/14 02:54 PM
05/07/14 02:54 PM
Carillo steel rods with L19 bolts You can't go wrong no matter what power level on gasoline Olivers steel billet are cheaper though
Re: Rods [Re: copchaser] #1616945
05/07/14 08:13 PM
05/07/14 08:13 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Oliver steel in my 557
