Pro or Con to tapping the back of the intake for heat? #1616916
05/06/14 12:27 PM
05/06/14 12:27 PM
a cornfield near you
BlakDak Offline OP
BlakDak  Offline OP
Its a 360
What are your thoughts on tapping the rear of the intake for heater ports, instead of off the intake and water pump?
Re: Pro or Con to tapping the back of the intake for heat? [Re: BlakDak] #1616917
05/06/14 10:04 PM
05/06/14 10:04 PM
BlakDak Offline OP
BlakDak  Offline OP
Bueller?
Re: Pro or Con to tapping the back of the intake for heat? [Re: BlakDak] #1616918
05/06/14 10:39 PM
05/06/14 10:39 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
You mean to get warmer heat?
I guess do whatever makes you happy
Re: Pro or Con to tapping the back of the intake for heat? [Re: BlakDak] #1616919
05/06/14 10:40 PM
05/06/14 10:40 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
Its a 360
i did it cuz it looked cool.. did it help? who knows..
Re: Pro or Con to tapping the back of the intake for heat? [Re: SpareParts] #1616920
05/06/14 11:45 PM
05/06/14 11:45 PM
BlakDak Offline OP
BlakDak  Offline OP
I just wondered if there any positives for doing it, or if it would screw something up.
Re: Pro or Con to tapping the back of the intake for heat? [Re: BlakDak] #1616921
05/06/14 11:59 PM
05/06/14 11:59 PM
The water leaving the intake manifold will be hottor than at the rear of the motor, the heads do most of the heating on the coolant
Re: Pro or Con to tapping the back of the intake for heat? [Re: BlakDak] #1616922
05/07/14 12:57 AM
05/07/14 12:57 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Could screw up the flow as in no flow/no heat.
No seriously, the flow through the heater core is quite a distance. So the best route is from the water pumps high and low pressure sides at the pump for best flow to the heater core.
But there can be alternate routes, as long as at least one side of the feeds or returns goes to the water pump.
I believe the positive flow from the water pump goes into the upper intake on the SB, so you could feed the heater core from that at the back and send the return from the heater core back to the water pump and it should work fine, IMO
But ,Im going to ask, Who runs a SB anymore
Re: Pro or Con to tapping the back of the intake for heat? [Re: Sport440] #1616923
05/07/14 10:26 AM
05/07/14 10:26 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
There more SB racers that BB.
Re: Pro or Con to tapping the back of the intake for heat? [Re: babarracuda] #1616924
05/07/14 10:37 AM
05/07/14 10:37 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
There are also more losers than winners...
Re: Pro or Con to tapping the back of the intake for heat? [Re: babarracuda] #1616925
05/07/14 02:50 PM
05/07/14 02:50 PM
Really Where
Re: Pro or Con to tapping the back of the intake for heat? [Re: BlakDak] #1616926
05/07/14 04:01 PM
05/07/14 04:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Its a 360
You need one in the front intake crossover , the water will be coming OUT of those 2 locations , you would have no water flow thru the heater core.
Re: Pro or Con to tapping the back of the intake for heat? [Re: JohnRR] #1616927
05/07/14 04:11 PM
05/07/14 04:11 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I did it to my 408, I was told it evens the flow out as theres no dead head point at the back of the intake. Didnt bother my heater at all.
Pluss it looks cool!!
I figured if the NASCRAP boys do it on a 500 MILE 700+ HP at 8K all day long, I figured it must do something as their cooling setups are similar.
Re: Pro or Con to tapping the back of the intake for heat? [Re: BigBlockMopar] #1616928
05/07/14 04:21 PM
05/07/14 04:21 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
ouch
Yeah, it's got a smallblock.
Re: Pro or Con to tapping the back of the intake for heat? [Re: Moparnut426] #1616929
05/07/14 10:58 PM
05/07/14 10:58 PM
BlakDak Offline OP
BlakDak  Offline OP
You wouldn't happen to have a picture of how you did it?
