Re: CHEAP rear axle options for a 73 Dart Sport ?
[Re: Kern Dog]
#1616858
05/06/14 10:36 AM
05/06/14 10:36 AM
Posts: 15,487 Florida
scratchnfotraction
corret. a 94 jeep cherokee has the 43" perch centers..you will have to move them to the bottom of axle tube. IIRC, it is same as A-body axle width or very close. you can find the 8 1/4 or a dana 30/35 in the jeeps. the DAK rear axle are B-body size IIRC..or they use B-body 8 3/4 under them.. durango 8 1/4 or 9 1/4 may be a option..they look to have a 43" perch center but I have not been around one to measure yet. I have the A-body 8 3/4 in my 88-440 truck tucking 12" wide rims in the fenders. when I measured up the 94 jeep axle it got me the same measurements. drum to drum and spring perch (just wrong side of tube...used the top perches to line up the lower perches with the u-bolts) the ferd exploder 8.8 is another one ez to stick under A-body disc brakes 3.73/4.10 gears. the early 64-65 mustangs have the 9" or 8" rear axle that will fit under the A-body.. not sure if it bolts right in but supposed to be correct drum to drum. good luck junk yarding
[Re: scratchnfotraction]
#1616859
05/06/14 02:17 PM
05/06/14 02:17 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I would think another 8.25 from a Dart or Duster would be the easiest option, usually people are giving them away and its a drop in. I had a good one here in CT I could not give away for $150
"I think its got a hemi"
[Re: Kern Dog]
#1616861
05/06/14 03:33 PM
05/06/14 03:33 PM
Posts: 25,918 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Besides the width and spring perch locations, take into consideration the pinion offset when shopping for an alternate rear end.
[Re: Kern Dog]
#1616863
05/06/14 07:00 PM
05/06/14 07:00 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
The 8-1/4 is strong enough for a typical street car. The weak link are the axles. They taper near the differential.
Dutchman builds some nice axles without the taper and at a good price. Kirk stuck them in his 75 Dart with a 3.55 limited slip out of a Dakota.
[Re: RapidRobert]
#1616868
05/07/14 09:55 AM
05/07/14 09:55 AM
scratchnfotraction
Michael I am in that same position with perches. did you just locate the new perches underneath (vertical plumb) from the OE top ones via the ubolts to locate the axle side to side? and then tilted the housing down to get the right nose down angle you wanted & then welded em?
Robert, yes. that is how I did it. used a level on the top perch while i adjusted pinion angle/squared up the perch center. tack weld perch to axle the removed axle to fully weld perch boxing the perch ends closed.
we used a94 jeep rear axle under a 69Dart to move around the yard..bolted the axle under the spring. then installed the A100 front straight axle/leafs to level the front off for a gasser build...never finished the steering/scraped it all for beer $
[Re: gdonovan]
#1616872
05/07/14 12:38 PM
05/07/14 12:38 PM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
Buddy of mine has an A body 8-1/4 he paid $300 for. SG with 4.10 gears. They are out there. Just have to be patient.
