CHEAP rear axle options for a 73 Dart Sport ? #1616857
05/06/14 05:35 AM
05/06/14 05:35 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Soon I'm going to fix up a 73 Dart Sport 340 to sell. The 73 model is supposed to have an 8 1/4" unit with 3,21 or 3.55 gears. Currently the car has a B body 8 3/4" axle. I'd rather keep the B axle for another project. These cars are really thinning out at our wrecking yards so I'm looking outside of a factory A body axle for this car.
I'm thinking of using another model of 8 1/4" axle. I thought I read somewher that Jeep Cherokees and Dakotas used these and the widths are close. Anyone here ever tried these? I'm aware that I will need to weld spring perches on.
Thanks, Greg
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: Kern Dog] #1616858
05/06/14 10:36 AM
05/06/14 10:36 AM
scratchnfotraction Offline
corret. a 94 jeep cherokee has the 43" perch centers..you will have to move them to the bottom of axle tube.
IIRC, it is same as A-body axle width or very close.
you can find the 8 1/4 or a dana 30/35 in the jeeps.
the DAK rear axle are B-body size IIRC..or they use B-body 8 3/4 under them..
durango 8 1/4 or 9 1/4 may be a option..they look to have a 43" perch center but I have not been around one to measure yet.
I have the A-body 8 3/4 in my 88-440 truck tucking 12" wide rims in the fenders. when I measured up the 94 jeep axle it got me the same measurements. drum to drum and spring perch (just wrong side of tube...used the top perches to line up the lower perches with the u-bolts)
the ferd exploder 8.8 is another one ez to stick under A-body disc brakes 3.73/4.10 gears.
the early 64-65 mustangs have the 9" or 8" rear axle that will fit under the A-body.. not sure if it bolts right in but supposed to be correct drum to drum.
good luck junk yarding
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: scratchnfotraction] #1616859
05/06/14 02:17 PM
05/06/14 02:17 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I would think another 8.25 from a Dart or Duster would be the easiest option, usually people are giving them away and its a drop in. I had a good one here in CT I could not give away for $150
"I think its got a hemi"
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: gdonovan] #1616860
05/06/14 03:16 PM
05/06/14 03:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I'm not so sure about that. People seem to be getting stupid money for A-body parts over on FABO.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: Kern Dog] #1616861
05/06/14 03:33 PM
05/06/14 03:33 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Besides the width and spring perch locations, take into consideration the pinion offset when shopping for an alternate rear end.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: John_Kunkel] #1616862
05/06/14 03:40 PM
05/06/14 03:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
last guy put a cherokee 8.25 into my 73 dart sport. if I was to do it I would do the ford 8.8.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: Kern Dog] #1616863
05/06/14 07:00 PM
05/06/14 07:00 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The 8-1/4 is strong enough for a typical street car. The weak link are the axles. They taper near the differential.
Dutchman builds some nice axles without the taper and at a good price. Kirk stuck them in his 75 Dart with a 3.55 limited slip out of a Dakota.
- Stu Harmon
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: scratchnfotraction] #1616864
05/06/14 07:37 PM
05/06/14 07:37 PM
Michael I am in that same position with perches. did you just locate the new perches underneath (vertical plumb) from the OE top ones via the ubolts to locate the axle side to side? and then tilted the housing down to get the right nose down angle you wanted & then welded em?
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: Kern Dog] #1616865
05/06/14 09:00 PM
05/06/14 09:00 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
1st gen Dakota rear will work flipping the perches.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: Dan Halen] #1616866
05/06/14 11:06 PM
05/06/14 11:06 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
cheap = GM 10 bolt
I am truckless..
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: 340SHORTY] #1616867
05/07/14 04:17 AM
05/07/14 04:17 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Thanks Shorty....The lug pattern makes that a no-go.
An axle a bit wider isn't a bad thing. The rear wheelwells of the Dart Sport/Duster/demon can accomodate it.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: RapidRobert] #1616868
05/07/14 09:55 AM
05/07/14 09:55 AM
Robert, yes. that is how I did it. used a level on the top perch while i adjusted pinion angle/squared up the perch center. tack weld perch to axle the removed axle to fully weld perch boxing the perch ends closed.
we used a94 jeep rear axle under a 69Dart to move around the yard..bolted the axle under the spring. then installed the A100 front straight axle/leafs to level the front off for a gasser build...never finished the steering/scraped it all for beer $
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: scratchnfotraction] #1616869
05/07/14 10:02 AM
05/07/14 10:02 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
$ is very important.
I am truckless..
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: feets] #1616870
05/07/14 11:23 AM
05/07/14 11:23 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
typical? im running 12.30's in the aspen with one.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: kissmyaspen] #1616871
05/07/14 12:29 PM
05/07/14 12:29 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I think Dick Landy's Duster had one too and Direct Connection beat the heck out of it testing stuff.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: gdonovan] #1616872
05/07/14 12:38 PM
05/07/14 12:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Buddy of mine has an A body 8-1/4 he paid $300 for. SG with 4.10 gears.
They are out there. Just have to be patient.
Re: CHEAP rear axle options for a 73 Dart Sport ? [Re: slantzilla] #1616873
05/07/14 06:37 PM
05/07/14 06:37 PM
P
Paul_Fancsali Offline
P
I ran 3.90 8.25 rear for years in my 73 finally broke spider gears with slicks so switched to 8.75. But I was only making 290 horsepower at the time.
