How to remove trim? #1616802
05/06/14 12:43 AM
05/06/14 12:43 AM
Orleans, Ontario
moparcanuk Offline OP
Orleans, Ontario
Is there an easy way to remove the chrome trim around the headrests from a 69 B body?
Re: How to remove trim? [Re: moparcanuk] #1616803
05/06/14 01:27 AM
05/06/14 01:27 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Doesn't it just fall off from old age ?!?!?
Re: How to remove trim? [Re: Stanton] #1616804
05/06/14 03:10 AM
05/06/14 03:10 AM
Orleans, Ontario
Orleans, Ontario
It's held on by very strong glue that has crystallized. You can't even cut through it. I need something to dissolve it.
Re: How to remove trim? [Re: moparcanuk] #1616805
05/06/14 05:14 AM
05/06/14 05:14 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
heat, use a hair dryer and take your time.
Re: How to remove trim? [Re: SCATPK] #1616806
05/06/14 04:23 PM
05/06/14 04:23 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I can't recall if the trim is chrome over plastic, or metal.
If metal I would not hesitate using acetone. If you are not re-using the upholstry, cut it off and soak, then scrape it off with a bondo spreader ot wooden stick.
