How to have a dipstick with a stroker crank #1616760
05/05/14 10:16 PM
05/05/14 10:16 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
I built a HEMI with a 4.5" stroker crank and Charlie's oil pan with no provision for a dipstick. I guess that is what I get for putting racing parts in a street car. But, with all of the money invested in the engine, I wanted a way to check the oil level.
A friend of mine who is a long time Mopar racer and fabricator, now has a special welding business catering to the power industry. I explained my delima to him and in just a couple of hours, he produced the solution. By drilling a hole through the drain plug, then using common fittings from the hardware store, I have a dip stick tube coming off of my drain plug!
Re: How to have a dipstick with a stroker crank [Re: Hemi ragtop] #1616761
05/05/14 10:17 PM
05/05/14 10:17 PM
Tennessee
Tennessee
The top side of the tube.
Re: How to have a dipstick with a stroker crank [Re: Hemi ragtop] #1616762
05/05/14 11:40 PM
05/05/14 11:40 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I hate to be critical, but that has the potential to do much more harm than good. First, that low pan in a street car is "iffy" -at least where I live(bad roads) Then, the drain you added is even lower in a non protected spot. The other issue, is with ANY positive crankcase pressure, you will be pumping oil out of your dipstick onto your headers/ engine bay. I tried something similar, and had so many issues that I gave it up.
Re: How to have a dipstick with a stroker crank [Re: Hemi ragtop] #1616763
05/06/14 01:14 AM
05/06/14 01:14 AM
I grind the side of the oil pan rails so a stock dipstick tube and dipstick will work on any aluminum oil pan I use I have freinds who go to a hydraulic shop and have clear site glass tubes fabbed up to fit onto the sides of the oil pans, that is way to complicated for me
Re: How to have a dipstick with a stroker crank [Re: Hemi ragtop] #1616764
05/06/14 03:54 PM
05/06/14 03:54 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
That's actually similar to what the factory did on the big block trucks. Except for incorporating the drain plug part.
Re: How to have a dipstick with a stroker crank [Re: Jwilli500] #1616765
05/06/14 07:30 PM
05/06/14 07:30 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Good idea. I agree the piece that hangs below the pan bothers me. Quick fix, allen pipe plug in the bottom. Bend the tube slightly so the Tee is higher than the bottom of the pan, Problem solved.
Doug
Re: How to have a dipstick with a stroker crank [Re: dvw] #1616766
05/06/14 09:41 PM
05/06/14 09:41 PM
Tennessee
Tennessee
Thanks for the replies, and constructive criticism. I built the car to drive, but as friends saw it come together, they convinced me to show it. Well, in two years, I have more trophies than my grandson can fit in his bedroom. Now I want to DRIVE it! Of course I have a significant investment in the engine, (anyone who has built a HEMI understands), and I want to protect it. Taking off for a two or four day long distance weekend is what I am looking for, NO TRAILER. But I want the assurance that all is well. Therefore the dipstick.
Re: How to have a dipstick with a stroker crank [Re: Hemi ragtop] #1616767
05/07/14 10:57 PM
05/07/14 10:57 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Silly question...........but why do you NEED a dipstick. I mean we all change oil in these type cars on a regular basis. Plus if it does not leak oil or smoke.......where is the oil gonna go between changes that you need to check it?
Monte
Re: How to have a dipstick with a stroker crank [Re: Monte_Smith] #1616768
05/08/14 08:34 AM
05/08/14 08:34 AM
Tennessee
Tennessee
under normal circumstances, you are right. However, I had an intake gasket leak that didn't show up in smoke, pipes were even light grey. Found the problem when I changed oil and was down a couple of quarts in 500 miles. Fixed with Proformance gaskets, but that made me want to be able to check oil without draining it. Just peace of mind.
Re: How to have a dipstick with a stroker crank [Re: Hemi ragtop] #1616769
05/08/14 08:57 AM
05/08/14 08:57 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We usually drill a hole in the side of the pan and weld a block of aluminium drilled and tapped for the truck style dipstick or just weld a block and tap it for a 90 degree fitting with a pipe thread on one side and a compression thread on the other.Use a tube and compression fitting correct for the tubing.Putting the dipstick below the windage tray or screen will keep it away from the rotating parts.Another esay way is weld a thick block and thread it to accept a site glass similar to what is used on hydraulic tanks on heavy equipment.The ones that have a round 1" glass face is easy to see and cheap
Re: How to have a dipstick with a stroker crank [Re: Hemi ragtop] #1616770
05/08/14 09:54 AM
05/08/14 09:54 AM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Which blocks don't come with a dipstick hole? I have a mega block and it had the hole in the factory location. The engine builder pluged it with an Allen screw but I put a dipstick in the motor.
Re: How to have a dipstick with a stroker crank [Re: DodgeCharger] #1616771
05/08/14 10:02 AM
05/08/14 10:02 AM
an8sec70cuda Offline
My KB block has the dipstick hole.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How to have a dipstick with a stroker crank [Re: an8sec70cuda] #1616772
05/08/14 10:49 AM
05/08/14 10:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I did something like this for my buddy on his ford...
I bent a 3/8 tube with a 90* and used a bulk head
fitting in the pan with a compression fitting... the
oil is up in the tube to the oil level and it worked
fine.. didnt have to mess with the drain fitting
Re: How to have a dipstick with a stroker crank [Re: MR_P_BODY] #1616773
05/08/14 10:52 AM
05/08/14 10:52 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
this is the same thing I did with the X-Block as it had no hole in the block for the tube.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: How to have a dipstick with a stroker crank [Re: Jwilli500] #1616774
05/08/14 11:44 AM
05/08/14 11:44 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
My 71 383 truck pan from Summit... plus, I agree about having a pan
hanging too low on a Hemi. I remember to vividly, 36 hours before I was to race on the flight deck of the USS Midway, I heard a loud thump
going across an intersection in my too low, 70 Challenger. A manhole
cover was loosened by the car in front of me & split the front seam
of the Milodon pan wide open... needless to say, I got a factory
Hemi pan after that trip.
Re: How to have a dipstick with a stroker crank [Re: Triggerfish] #1616775
05/08/14 07:51 PM
05/08/14 07:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Here's what i use. Sight glass off a Allison 9000 transmission.
