Re: How to have a dipstick with a stroker crank
[Re: Hemi ragtop]
#1616762
05/05/14 11:40 PM
05/05/14 11:40 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I hate to be critical, but that has the potential to do much more harm than good. First, that low pan in a street car is "iffy" -at least where I live(bad roads) Then, the drain you added is even lower in a non protected spot. The other issue, is with ANY positive crankcase pressure, you will be pumping oil out of your dipstick onto your headers/ engine bay. I tried something similar, and had so many issues that I gave it up.
[Re: Hemi ragtop]
#1616764
05/06/14 03:54 PM
05/06/14 03:54 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
That's actually similar to what the factory did on the big block trucks. Except for incorporating the drain plug part.
[Re: DodgeCharger]
#1616771
05/08/14 10:02 AM
05/08/14 10:02 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
My KB block has the dipstick hole.
[Re: an8sec70cuda]
#1616772
05/08/14 10:49 AM
05/08/14 10:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I did something like this for my buddy on his ford... I bent a 3/8 tube with a 90* and used a bulk head fitting in the pan with a compression fitting... the oil is up in the tube to the oil level and it worked fine.. didnt have to mess with the drain fitting
[Re: Jwilli500]
#1616774
05/08/14 11:44 AM
05/08/14 11:44 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
My 71 383 truck pan from Summit... plus, I agree about having a pan hanging too low on a Hemi. I remember to vividly, 36 hours before I was to race on the flight deck of the USS Midway, I heard a loud thump going across an intersection in my too low, 70 Challenger. A manhole cover was loosened by the car in front of me & split the front seam of the Milodon pan wide open... needless to say, I got a factory Hemi pan after that trip.
